Home > Maintenance & Mods (L405) > Rear lens replacement L405 |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3824 |
Yep, I touched the reflector on my l322 foglight - the silvering then just wipes off. DO NOT TOUCH!!! Geoff |
28th Jan 2022 12:55pm |
number76 Member Since: 30 Oct 2013 Location: UK Posts: 47 |
Hi, where did you find your replacement lens for this year and model light please?, i see that powerful have the 12-17 model lens, but not the newer type.... 2014 L405 3.0 V6 Autobiography Santorini Black 49k |
29th Jan 2022 10:40am |
Pendle Member Since: 12 Dec 2021 Location: Hampshire Posts: 23 |
From powerful uk
29th Jan 2022 3:33pm |
Thanks.
29th Jan 2022 4:03pm |
I bought it in Dec 2021
29th Jan 2022 4:51pm |
gqii4you Member Since: 16 Feb 2022 Location: East Coast Posts: 3 |
Any update> How did it turn out? |
16th Feb 2022 4:07pm |
Hi gqii4you
17th Feb 2022 1:27pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35375 |
your 2016 should have the old style lights so have you replaced with the newer 2018 style ones?
17th Feb 2022 2:43pm |
Hi Stan, previous owner upgraded the lights, I broke one and found identical replacement, all codes are the same, but it does not work. Production date of previous one was 22/11/2019, 18MY. SVO EC. NON WORKING UNIT : 13/01/2020 18MY SVO EC
17th Feb 2022 3:43pm |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 871 |
The re-pinning is usually done on the light unit, not the loom from the car - so you’ll need to re pin your new light unit - it’s a fairly simple process, there’s a ‘how to’ on here somewhere… |
17th Feb 2022 4:19pm |
…here’s the re-pin you’ll need to undertake, the wires can be pulled out once you remove the red locking tab from the connector. Be sure to label the wires first, as they’re all black!
17th Feb 2022 4:24pm |
17th Feb 2022 4:26pm |
A big thank you to all of you that posted here.
23rd Feb 2022 10:56am |
FF777 Member Since: 21 Jan 2022 Location: London Posts: 17 |
I'm in the process of changing the lens if anyone is interested
2nd Mar 2022 6:37pm |
