Home > Maintenance & Mods (L322) > Suspension fault |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
There are quite a few threads on this around on here and if you look in the WM in the Wiki under suspension fault codes you'll see the code identfied and suggested possible causes.
12th Dec 2021 8:22pm |
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 |
Very easy to drill through the exhaust silencer. Do it off the vehicle and make sure all the swarf is blown out before refitting. Bish.
13th Dec 2021 1:41pm |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 737 |
noted RR 2005 4.4 petrol
13th Dec 2021 1:53pm |
16th Dec 2021 10:12am |
ok i found the breather, looks like new, so dose the commpressor, i havent removed it, dont know if i should RR 2005 4.4 petrol
16th Dec 2021 11:46am |
Hi Knares
16th Dec 2021 11:58am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
@ Knares, if i remember correctly that is the PRV - pressure relief valve.
16th Dec 2021 3:53pm |
rjff no you didn’t miss any thing, after reading C11ONX post it got me thinking about mine
19th Dec 2021 11:41pm |
