![]() | Home > Technical (L322) > High beam assist |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
Mine does that. I can see the light then it goes off again. |
darrenm Member Since: 06 Jan 2015 Location: chorley Posts: 182 ![]() ![]() ![]() |
What setting have people changed using iid tool to make it work |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 ![]() ![]() ![]() |
Mine's turned off as it's too slow to react. I'd be interested in recalibrating it though to see if that improves it. We have it on our X-Trail and on that it is excellent.
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1749 ![]() ![]() ![]() |
Mine has the High Beam Assist but i am able to turn it off in 2 ways.
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 490 ![]() ![]() |
As stated by others, your car would need to have been specified with the Vision Assist Pack, so you'd also have headlights that turn with the steering wheel above 10mph or whatever minimum speed it is, as well as 360 camera's and blind spot monitoring. If you do have it, then scroll through the menu on the instrument cluster and you'll find an option to enable or disable it. ![]() My Vogue SE with a load of other exta's had it, and to be honest I had it turned off. It was hopelessly slow to respond and blinded every oncoming driver. ![]() My new Volvo has auto main beam / headlights, and with it's mega 'burn every oncoming driver's retina's out' LED lights I also have it turned off, so still crap on a much newer car! ![]() Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
