![]() | Home > Maintenance & Mods (L322) > CV Boots |
Piet Member Since: 22 Mar 2017 Location: Maasdam Posts: 199 ![]() ![]() ![]() |
Maybe like this?
IGP Member Since: 09 Jul 2020 Location: Malvern Posts: 294 ![]() ![]() ![]() |
https://www.fullfatrr.com/forum/topic55527.html
Ricardo Villa Member Since: 01 Nov 2020 Location: Worcester Posts: 186 ![]() ![]() ![]() |
Thanks for response, only had boots changed I think shaft is original. Will check length to make sure. 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6416 ![]() ![]() |
Are the new cv boots of the harder plastic type, as opposed to the soft rubber type. I had a problem getting the harder plasticky one to stay put in my car. I believe positioning of the clip is the key, and clean surfaces for a good grip.. .
Garage fitted them, they did seem quite stiff and guy doing it said how hard they were to locate/fit. They have it now to resolve hopefully. Are the different types from different suppliers? 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
Manufacturers seem to have switched to the hard plastic ones. My original problem was with my Volvo V70, but just ordered a new boot for my wife's Audi TT and that too is the hard plastic type. .
Yes this appears the case and what garage has said. You would think garages would feedback these issues so they can be resolved. Think my garage is fed up with them! 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
Update, the New CV boots (GKN) just won’t stay on, came off again after short test drive. The material is just to stiff according to mechanic. Garage has fitted brand new Flexi Boots which are a much softer rubber. Only got home tonight so pitch black but will check them out tomorrow. Hopefully these will stay on. 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
