Home > Maintenance & Mods (L322) > CV Boots
Ricardo Villa
United Kingdom 2009 Range Rover Vogue TDV8 Bournville
CV Boots
I had my front outer CV boots replaced during a service 4 weeks ago. Noticed about a week after both had come loose, grease everywhere. Garage refitted with new clips last week. Noticed on Friday one had come off again and other one was loose and loosing grease. Is this a common issue as CV boots done on other cars never an issue. 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
2005 Jaguar XJ350 3.0 V6 Sovereign, Jaguar Racing Green, Ivory
1997 TVR Chimaera 450, Formula Red, Grey
Post #614088 29th Nov 2021 12:30am
Piet
Netherlands 2008 Range Rover Autobiography 4.2 SC V8 Lucerne Green
Maybe like this?
[url] https://www.fullfatrr.com/forum/topic55527.html[/url]
Post #614108 29th Nov 2021 8:37am
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
Link fixed 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #614109 29th Nov 2021 8:41am
Ricardo Villa
Thanks for response, only had boots changed I think shaft is original. Will check length to make sure. 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
Post #614111 29th Nov 2021 8:55am
Are the new cv boots of the harder plastic type, as opposed to the soft rubber type. I had a problem getting the harder plasticky one to stay put in my car. I believe positioning of the clip is the key, and clean surfaces for a good grip.. .
Post #614114 29th Nov 2021 9:37am
Ricardo Villa
Garage fitted them, they did seem quite stiff and guy doing it said how hard they were to locate/fit. They have it now to resolve hopefully. Are the different types from different suppliers? 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
Post #614170 29th Nov 2021 5:13pm
Manufacturers seem to have switched to the hard plastic ones. My original problem was with my Volvo V70, but just ordered a new boot for my wife's Audi TT and that too is the hard plastic type. .
Post #614184 29th Nov 2021 6:13pm
Ricardo Villa
Yes this appears the case and what garage has said. You would think garages would feedback these issues so they can be resolved. Think my garage is fed up with them! 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
Post #614213 29th Nov 2021 11:48pm
Ricardo Villa
Update, the New CV boots (GKN) just won’t stay on, came off again after short test drive. The material is just to stiff according to mechanic. Garage has fitted brand new Flexi Boots which are a much softer rubber. Only got home tonight so pitch black but will check them out tomorrow. Hopefully these will stay on. 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
Post #614336 1st Dec 2021 12:18am
