Home > My Range Rover > My L322 Project
Page 5 of 8 <12345678>
dhallworth
Will have a look shortly Smile
I've just had the entire rear subframe off mine, replaced every single bush and balljoint on it (and the front too) all 4 bearings, and both diffs and whilst everything has been off it's been rust treated, zinc primered and then coating in Bilt Hamber Epoxy Mastic. Made life much easier doing it all whilst the subframe was off Smile
What trim strip did you use to go over the wheel arch and onto the liner? I'd like them on mine but am not sure what to look for.
Post #628554 13th Apr 2022 11:41am
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Here you go David, this is the wheel arch sealing strip I used. Fits like a glove.
https://www.ebay.co.uk/itm/112160185092 Christian.
Current Cars
2011 Range Rover Vogue SE
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #628561 13th Apr 2022 12:23pm
dhallworth
Bow down
Superb! Thank you!
Was 1 meter enough for each wheel arch or did you need 2? 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #628565 13th Apr 2022 12:27pm
Caesium
I only bought 1 metre and that was enough for both arches. Christian.
Current Cars
2019 BMW X4
or
Post #628567 13th Apr 2022 12:29pm
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Christian, why that style of rubber strip?
I thought that this type was the correct one
https://www.ebay.co.uk/itm/121796822559
Thanks
David Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #628619 13th Apr 2022 6:23pm
Caesium
David, I used the type with the lip because the U type does not effectively stop dirt laden water getting between the wheel arch liner and the arch.
My arches had the start of some corrosion due to the gap between the liner and the arch lip so this additional rubber lip will prevent about 80% of that water getting into that area as it’s really tight to the liner. Christian.
Current Cars
2019 BMW X4
or
Post #628622 13th Apr 2022 7:58pm
bigbo
Thanks, useful information
MG TF 2003
Post #628639 13th Apr 2022 10:16pm
kevinp
I used the u shape rubber because I wanted to completely cover the wheel arch lip from stone damage. Water will still get behind any 'seal' unless you fill it with silicone or the like first.
It's not really a seal if you think about it. I think of it as a protection strip.
Post #628640 13th Apr 2022 11:03pm
Caesium
The car is currently looking like this, can anyone guess what is being done this time?
No prizes other than the glory if you are right.... Laughing
 Christian.
Current Cars
2019 BMW X4
or
Post #628675 14th Apr 2022 3:23pm
dhallworth
Wheel refurb? 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #628679 14th Apr 2022 4:01pm
GraemeJudge
2004 Range Rover Vogue Td6 Java Black
Converting it to run on rails 🚂
Post #628684 14th Apr 2022 6:15pm
colalowe
United Kingdom 2012 Range Rover Autobiography TDV8 Buckingham Blue
What a fantastic write up, I have had to change the same suspension components on mine, I also need to change the centre prop bearing and I’m just waiting on a gearbox flush.
I’m glad to see that I’m not alone in having to or wanting to replace all the same components. Thumbs Up
Post #628960 18th Apr 2022 11:53am
colalowe
Post #628961 18th Apr 2022 11:53am
Caesium
Thanks very much for that, it's always good to see positive feedback. It helps to motivate me to keep documenting it!
I'm not sure I'd have a flush on the gearbox BTW, I've heard mixed things and ZF don't recommend it. Christian.
Current Cars
2019 BMW X4
or
Post #628973 18th Apr 2022 1:17pm
ergobyte
France 2012 Range Rover Vogue 4.4 V8 Java Black
'bout your LED choice...
Hi,
This thread is fantastic !
and I'm sorry but I'd like to have your opinion on a choice you made about LEDs.
QUOTE:
"Headlight bulbs.
My HID's were looking a little dull and yellowing so I bought some OSRAM replacements.
If you do this, don't buy cheap knock off bullbs or you'll have all sorts of issues with overheating, beam pattern, dazzling, radio interference, CAN BUS errors etc. Stick with Philips or Osram.
They are D3S on my MY2011 so I went for OSRAM Cool Blue Intense Xenarc"
SO you won't change Your DS3 with Led ones ? Can you please elaborate ?
Thanks again for a wonderful Thead Thumbs Up "it needs some intelligence to undestand you may not have enough"
Post #629353 22nd Apr 2022 7:59am
