![]() | Home > Technical (L322) > Slight power loss 2300 to 2500 rpm - 4.4 TDV8 |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
Hi all
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3817 ![]() ![]() ![]() |
Cleaning out the plenum and throttle body made mine feel like it had 3 turbos.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
On my list of jobs to do! It's filthy job by looks of it. I recall a DIY thread sometime ago Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
The state my MAP sensor when I took it off to clean I can only imagine what's inside. I think cleaning the throttle body would be fairly simple and in car job with some brake cleaner and a toothbrush but for the plenum itself I'd be tempted to buy a cleaned S/H one rather than try to clean it myself as I just don't have the facilities to deal with that amount of black filth........ 2012 TDV8 Vogue (L322) |
I would be very wary of buying a secondhand plenum off eBay or similar.
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1295 ![]() ![]() ![]() |
This was in mine and more!! Easier to take the throttle body off to clean it.
I'm now itching to do it! I love the smell of Gunk |
Rob, get some wire coat hangers, flexible metal strips, long handled fine wire brushes, shaped scrapers, bunches off cloth tied to string, more scrapers, decorators shaving hook and anything else you have lying around. Easy. LOL. And disposable gloves or you will have black hands for a week!! |
£500 seems cheap compared to dealing with that mess..... 2012 TDV8 Vogue (L322) |
Thank you everyone for the replies and suggestions.
There is a DIY thread on here on how to remove it.
Why don't you just take the MAP sensor out the top of the plenum chamber and clean it first. I'll more or less guarantee it is clogged up. If that doesn't improve things make sure the secondary turbo activator is free to move. It opens roughly at the rpm you state.
Kevin,
Thanks Mike. Didn't realise it gave a code if it gets stuck. I've still got a conversion kit sitting on my garage shelf after you highlighted the problem. |
