![]() | Home > Technical (L322) > Slight power loss 2300 to 2500 rpm - 4.4 TDV8 |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
Yet more great advice from this forum!
Hi everyone,
I’m assuming you have a GAP IID tool and have run a full fault check? 2012 TDV8 Vogue (L322) |
Yep, and all clean (except for the usual speaker related errors, driver/passenger seat, etc). Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2641 ![]() ![]() |
Have you tried swapping MAFs to check for any improvement?
I haven’t tried swapping MAF sensors, only cleaned them.
I did not know that. I thought the first turbo was smaller so it spooled up more quickly, and the second turbo was larger for when the revs and extra gas flow / boost was needed! So does the actuator flip from the first to second turbo, or does it just bring in the second turbo to boost along with the first? I thought it flipped from one to the other… I’ll have to reread the manual again methinks… Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
The turbos are sequential. The primary isn't so large that it can't spool up fairly quickly, helped by having variable vanes and the secondary is a helper for higher revs and loads. |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 818 ![]() ![]() |
I would call them parallel sequential. The larger primary variable vane turbo stays on. The secondary fixed vane turbo comes on additionally at about 2400rom. |
Have you checked for the level of vacuum available and made sure there are no leaks? Also check for oil in the vac. lines, this can indicate a vacuum pump issue, make sure all actuators and solenoids using vacuum are functioning correctly. You'll probably need a hand vacuum pump like a 'MitiVac' and a handful of adaptors and bits of pipe. |
Cheers Phoenix,
hotpotatojr Member Since: 05 Oct 2021 Location: Blackpool Posts: 71 ![]() ![]() ![]() |
Can I ask, where you got the EGR mapped out? Also appreciate info on how/where you got the TCU updated and feedback on the latest software.
I had the EGR blanked and mapped out by DTA London, which is based at Dartford Transmissions - who are highly knowledgeable and recommended.
Great thanks. I'm looking to do the same but also DPF coded out but I'm up north so looking for someone reputable.
