![]() | Home > Technical (L322) > Range Rover L322 ABS issue |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 596 ![]() ![]() ![]() |
This sounds like the yaw rate sensor. While you cannot remove it without taking the cubby and center console apart, there is a way to access the connector. Try unplugging and reconnecting as follows:
Have you considered a low voltage problem for whatever reason? |
Wolf63 Member Since: 12 Jun 2014 Location: Visp Posts: 4 ![]() ![]() |
Hello Thank you for your reply!
Try unplugging, cleaning contacts and reconnecting. Then clear any registered faults. Might not be the cause but it's easy enough and therefore worth a try... |
The reason l mentioned possible low voltage is that low voltage fairly commonly causes the problem you are experiencing ie abs, dsc, hdc and air suspension faults all together. Although your battery is good it is a possibility that you have an intermittent connection fault causing your problems.
