Home > Technical (L322) > Fault Code from Diagnostics - 'Engine Stability Control'??
Alex 111s
Scotland 2003 Range Rover HSE Td6 Zermatt Silver
Hi Guys,
My FFRR (53 plate TD6) has developed a shudder as it passes through the revs. it's particulaly noticable when cruising at about 55mph and you ease on the throttle to spped up (not as noticable if you bury the pedal into tthe carpet)
My local Indie has had a look and hooked it up to the diagnostics & it showed an 'Engine Stability Control' fault.
this is a new one on me and the garage - anyone got any info on this that could help.
cheers,
Alex.
Post #66323 30th May 2011 9:43am
Active engine mount ? 2008 MY Supercharged
Post #66324 30th May 2011 9:48am
daveo
is the shudder while driving,like going over a small cattle grid. do you notice it if you excellerate very lightly up to the said speed, whats the mileage
on the car... V8 facelift Range Rover Autobiography 22" wheels.
Post #66349 30th May 2011 2:46pm
jonminns
United Kingdom 2008 Range Rover Vogue TDV8 Santorini Black
Interesting, I have noticed this on my 4.4 petrol over the last few days, I also have a check engine light (possibly lpg related)
Mine's only under light acceleration and seems to be coming from the back? Sounds exactly like a small cattle grid and is apparent from 35/40-55mph 2008/58 FFRR 3.6 TDV8 Vogue
Post #66418 31st May 2011 3:01am
Alex 111s
on the car...
Yes - I suppose that it coulsd be described like that and it is under light acceleration.
Cheers
Post #66596 1st Jun 2011 11:51am
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
Any update on this boys?
Post #80122 9th Sep 2011 6:47pm
Well no but as I read it the TD6 has one active engine mount . If this wold fail would that not be the diagnostic message ?
as for jominns I don't think your engine has an active mount so you won't get the same message. 2008 MY Supercharged
Post #80180 9th Sep 2011 11:03pm
Ashjw
England 2004 Range Rover Vogue 4.4 V8 Buckingham Blue
"Engine stability control" usually caused by faulty fuel injector you need to get it rigged up to a decent machine that will give you injector flow rates
Post #93270 19th Nov 2011 12:46am
