![]() | Home > Technical (L322) > Fault Code from Diagnostics - 'Engine Stability Control'?? |
Active engine mount ? 2008 MY Supercharged
is the shudder while driving,like going over a small cattle grid. do you notice it if you excellerate very lightly up to the said speed, whats the mileage
jonminns Member Since: 07 Mar 2011 Location: Leicestershire, UK Posts: 155 ![]() ![]() ![]() |
Interesting, I have noticed this on my 4.4 petrol over the last few days, I also have a check engine light (possibly lpg related)
Alex 111s Member Since: 09 Feb 2010 Location: Aberdeen Posts: 14 ![]() ![]() ![]() |
Yes - I suppose that it coulsd be described like that and it is under light acceleration. Cheers |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
Any update on this boys? |
Well no but as I read it the TD6 has one active engine mount . If this wold fail would that not be the diagnostic message ?
Ashjw Member Since: 19 Nov 2011 Location: Leyland Posts: 2 ![]() ![]() ![]() |
"Engine stability control" usually caused by faulty fuel injector you need to get it rigged up to a decent machine that will give you injector flow rates |
