![]() | Home > Technical (L322) > Heater blowing cold (I doubt anyone else has had this fault) |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 933 ![]() ![]() |
Depends, just confirm your engine. Iv had similar but it looks like an air lock I had a small weep of coolant from my lpg vapouriser . All bled out and now seems fine.
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 ![]() ![]() ![]() |
Hi Dave, I have the 4.4 AJ engine. No FBH fitted.
Iv got 6he m62 but I'm sure the heating system is the same, I had to remove the rad top hose in the end to bleed out the air locks I poured coolant down the hose hose direct to the thermostat and into the rad it's self. Then reconnected and final stage was to pull the small hose off the top of the rad that feeds back to the expansion bottle and blow down it several times forcing cooland and any trapped air to come out of the expansion cap hole each time topping up via the small hose again with coolant. It was a |
" And doesn't the jag engine have a factory fault with incorrect wiring to the aux heating pump ?"
coopss Member Since: 21 Apr 2018 Location: Hampshire Posts: 281 ![]() |
I had the same issue. I had the FBH changeover valve rebuilt
I wish I did, would have probably been an easy fix |
There is a teck bulletin for the coolant pump where the wires were crossed over in the factory essentially making the pump work in reverse, I'm sure iv read it on here I'm just trying to track it down |
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 339 ![]() ![]() ![]() |
Here you go:
Thanks Guys, But unfortunately wired correctly.
OK FSR fitted & exactly the same |
Update :- Heater works fine with everything connected - But temperature drops when revs exceed 1500 RPM (20 degrees C). Drop below these revs & instant heat again (26 /27 Degrees C).
telly-addict Member Since: 22 Mar 2019 Location: Morayshire Posts: 139 ![]() ![]() ![]() |
I'm not familiar with the system but I read your thread with interest. It occurs to me that there must be another valve controlling water flow between the main circuit and the heater matrix circuit. Similar to the FBH I suppose but obviously different as you don't have that fitted. Cam
There are no other valves
Cheers Dave. Yes definitely no other valves. I have decided to replace the water pump & all hoses. Including the Oil mixer control valve, As this is all that's left.
