******* FIXED - Well sort of ******************
I thought that I had an issue with the viscous fan ( it didn't seem to kick in & would spin easily). So I changed that.
I also removed the the themostat completely at the same time & would you believe it, I have heat all the time at 60 /70 MPH on the Motorway
However & here is the however, the engine is Not reaching operating temperate at this speed. I have had it down to as low as 56 degrees C (still with heat out of the vents).
Before removing the thermostat, I heated it up & confirmed that is statred to open around 85 degrees & was fully open at 98 degrees.
My question is what do I do now, Try another thermostat (that will be the third) or add some holes the existing one to allow a little more flow. ![Banging Head Banging Head](images/smiles/icon_banghead.gif)
