![]() | Home > Technical (L322) > Supercharged Coolant Problem - Temp Gauge Dropping |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
All you need is the ID and thickness of teh o ring - you will get one from any engineering supplies company. |
Based on a bit of internet research, I would suggest Nitrile over Viton. Nitrile has the lower heat range (up to 120 C) but better resistance to engine coolant fluids than Viton. Close finish though, Viton will probably also do fine. Buy one of both and if the Nitrile fails, switch to the Viton would be my solution |
RRBlue Member Since: 24 Feb 2012 Location: Cambs Posts: 222 ![]() ![]() ![]() |
Thank you. Such a relief to find someone to discuss o-rings with. Not many takers at home for some reason. 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
All done. The old o ring was completely shot: damaged from having stuck to the aluminium casting and misshapen from age and heat.
The replacement is 3.5mm cross section and 34.5mm internal diameter. A five minute job, followed by weeks of bleeding the cooling system, but better than paying �90 for the replacement connector which you have to buy with the two hoses attached. I hope this helps others. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated :mrgreen: 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4 2005 4.2 Supercharged Vogue SE & 2011 3.0SDV6 HSE Discovery 4 2002 4.4 Vogue 2000 4.6 Vogue 2010 Freelander 2 TD4 HSE 2009 Freelander 2 TD4.e 2009 1992 Mercedes 300D 1986 Renault 2.1 Turbo D 1976 Morris Marina 1.8 |
