Home > Technical (L322) > Electric Thermostat
staffs964
United Kingdom 2003 Range Rover HSE Td6 Epsom Green
Electric Thermostat
Hi
Does anyone know what item the photo is referring to, please?
My coolant temp works just fine, the auxiliary fan kicks in when it should.
Thanks
03 4.4 FF
 Brit in Canada
RHD 03 FF Td6
LDH 03 FF 4.4
Post #609156 14th Oct 2021 4:17pm
p38arover
Australia
The thermostat has a wax section that is heated by an electrical element to allow the thermostat to open further. Corrosion caused by leaking coolant where the electrical plug connects causes the wiring to go open circuit thus triggering the fault.
On mine the wires had corroded completely off the plug. One day I’ll terminate the wires with a resistor to make the ECU think the thermostat element is still intact. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #609257 15th Oct 2021 10:48am
staffs964
Thanks for the response Ron and duly noted.
However, I'm still unsure which thermostat it is referring to?
Thanks Brit in Canada
RHD 03 FF Td6
LDH 03 FF 4.4
Post #609273 15th Oct 2021 12:50pm
p38arover
Australia
Sorry, I should have made it clearer. It’s the engine coolant thermostat.
See https://www.fullfatrr.com/forum/topic39362.html Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #609328 15th Oct 2021 9:10pm
staffs964
OK Thank you, Ron
I'll check for that, it didn't occur to me as it appears to read the temperature fluctuations (0 to norm 105-107) just fine.
I will let you know. Brit in Canada
RHD 03 FF Td6
LDH 03 FF 4.4
Post #609498 17th Oct 2021 2:37pm
p38arover
Australia
It seems you are confusing the engine temp sensor with the thermostat. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #609535 17th Oct 2021 10:08pm
staffs964
Ok
Just took a look at my spare, I assume you mean #1 (as I see the thermostat behind it) and 2 is the temp Sensor (gauge).
I get it now, never occurred to me there may be an electrical connection to the therm.
Thx for you patience
 Brit in Canada
RHD 03 FF Td6
LDH 03 FF 4.4
Post #609641 18th Oct 2021 6:50pm
