Home > Technical (L322) > Electric Thermostat |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1536 |
The thermostat has a wax section that is heated by an electrical element to allow the thermostat to open further. Corrosion caused by leaking coolant where the electrical plug connects causes the wiring to go open circuit thus triggering the fault.
15th Oct 2021 10:48am |
staffs964 Member Since: 21 May 2016 Location: Ontario, Canada. Posts: 10 |
Thanks for the response Ron and duly noted.
15th Oct 2021 12:50pm |
Sorry, I should have made it clearer. It’s the engine coolant thermostat.
15th Oct 2021 9:10pm |
OK Thank you, Ron
17th Oct 2021 2:37pm |
It seems you are confusing the engine temp sensor with the thermostat. Ron B. VK2OTC
17th Oct 2021 10:08pm |
Ok
18th Oct 2021 6:50pm |
