Home > Technical (L322) > Help
C11ONX
Help
Hi all
Driving home the other night turned right and the car died. Coasted to a stop. Wouldn’t restart not enough power to raise the gear selector.
AA came out and jumped it, started straight away drove faultlessly home. Brought up the following codes. Any ideas where to start?
It has happened once before 14 months ago but it started up straight away then.
Post #607710 29th Sep 2021 5:03pm
Your profile isn't filled in so no idea of model or age.
You haven't listed any codes.
Sounds a strange one - was there no warning at all before it stopped ?
Post #607712 29th Sep 2021 5:07pm
mjdronfield
4.4 TDV8 if the gear selector raises….. or in this case, doesn’t.
Does indeed seem strange. I’d have to start with the codes and go from there…. Sounds like a power issue if you are seeing issues before the engine fails to start… alternator/loose connection perhaps…. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #607715 29th Sep 2021 5:38pm
C11ONX
I uploaded some pictures but they have disappeared.
It’s a 2011 4.4 tdv8. There was no warning it just died.
Post #607723 29th Sep 2021 7:45pm
Loose battery connection maybe? Got - 2017 SDV8 Autobiography in Loire Blue
Post #607725 29th Sep 2021 8:06pm
C11ONX
They are on tight. Was thinking it could be a faulty wire in the loom or a dodgy earth strap?
Post #607728 29th Sep 2021 8:18pm
Battery earth connection to body bad / loose or as you say faulty earth strap.
Might be worth fitting a supplementary earth strap. Thumbs Up
Post #607731 29th Sep 2021 8:25pm
C11ONX
Extra strap from the Engine to chassis? 2011 TDV8 | overfinch genuine build | mapped
Post #607732 29th Sep 2021 8:28pm
From the engine to any bodywork. Any suitable bolt or stud on the engine/ bell housing to a good earth point under the bonnet will suffice. I got one made up from welding cable, for flexibility, by an eBay seller to the correct length with the end lugs with the hole sizes l required.
Post #607753 30th Sep 2021 7:28am
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
You should be able to make a choice from this seller
https://www.ebay.co.uk/itm/222662654414?var=521515635838 2011 TDV8 Vogue SE
Post #607760 30th Sep 2021 8:30am
