Home > Technical (L322) > Help |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7926 |
Your profile isn't filled in so no idea of model or age.
29th Sep 2021 5:07pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7796 |
4.4 TDV8 if the gear selector raises….. or in this case, doesn’t.
29th Sep 2021 5:38pm |
C11ONX Member Since: 30 Sep 2018 Location: Huddersfield Posts: 15 |
I uploaded some pictures but they have disappeared.
29th Sep 2021 7:45pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6723 |
Loose battery connection maybe? Got - 2017 SDV8 Autobiography in Loire Blue
29th Sep 2021 8:06pm |
They are on tight. Was thinking it could be a faulty wire in the loom or a dodgy earth strap? |
29th Sep 2021 8:18pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3973 |
Battery earth connection to body bad / loose or as you say faulty earth strap.
29th Sep 2021 8:25pm |
Extra strap from the Engine to chassis? 2011 TDV8 | overfinch genuine build | mapped |
29th Sep 2021 8:28pm |
From the engine to any bodywork. Any suitable bolt or stud on the engine/ bell housing to a good earth point under the bonnet will suffice. I got one made up from welding cable, for flexibility, by an eBay seller to the correct length with the end lugs with the hole sizes l required. |
30th Sep 2021 7:28am |
dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450 |
You should be able to make a choice from this seller
30th Sep 2021 8:30am |
