Home > Technical (L322) > Fuel gauge question
Andy2986
United Kingdom 2011 Range Rover Vogue TDV8 Barolo Black
Fuel gauge question
Hi all
I have had the fuel gauge fault on my 4.4TDV8 for a while now. But then it fixed itself !!! And has been fine so i left it…
But now its back !!!! So now I will defiantly fix it.
Somewhere in the back of my mind i thought I read that when the car thinks its out of diesel (ie the fuel gauge reads empty and the warning on the dash is on) it stops the engine even though there is plenty of fuel in the tank?
Or will it run as normal until the diesel actually runs out ?
Hope its the latter and I’m just having a brain fart !!!
. 2011 4.4 TDV8
2000 4.6 P38
1998 D1 300tdi
Post #607685 29th Sep 2021 12:58pm
bishbosh10
There's a very detailed thread on fixing the common fault with one of the sender connections in the tank. The search function should find it for you.. Smile Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #607702 29th Sep 2021 3:20pm
Andy2986
I’m ok with fixing it, and have got the Landrover sheet that someone kindly sent to me.
My tank is too full at the moment to carry out the repair. Even though it’s reading nearly empty.
I was wondering what happens if I continue to drive the car when the gauge says it’s completely empty. 2011 4.4 TDV8
2000 4.6 P38
1998 D1 300tdi
Post #607704 29th Sep 2021 3:45pm
mjdronfield
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #607705 29th Sep 2021 3:49pm
Andy2986
Thanks for the info….
At least I know I wasn’t going mad !! 2011 4.4 TDV8
2000 4.6 P38
1998 D1 300tdi
Post #607707 29th Sep 2021 4:09pm
cass
From my own experience on a 4.4 TDV8 I know that it will cut the engine but it does give a brief warning with what feels like a misfire. Switching off and restarting seems to reset things but not for long (minutes not days)
I got around this by fitting a variable resistor across the sensor wires at the tank, this kept me going for a couple of months until the weather improved enough to motivate me to do the job properly.
Post #607741 29th Sep 2021 10:20pm
There is also a TSB available to explain the issue with the fuel pump wiring in the saddle tank and the car running out at 1/4 tank still showing on the gauge... Thumbs Up
Post #607745 29th Sep 2021 11:24pm
dexion7
2010 Range Rover Vogue SE TDV8 Alaska White
I can state for certain that my (now departed) 2010VSE 3.6 worked perfectly well with the fuel gauge cable fault inside the tank as I drove it like that for a few months without any issues. there was no warning on the dash other than the needle reading zero fuel. 2010 VSE [Roger]
Post #607820 30th Sep 2021 11:01pm
