![]() | Home > Technical (L322) > Fuel gauge question |
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 ![]() ![]() |
There's a very detailed thread on fixing the common fault with one of the sender connections in the tank. The search function should find it for you.. |
Andy2986 Member Since: 26 May 2019 Location: Suffolk Posts: 113 ![]() ![]() ![]() |
I’m ok with fixing it, and have got the Landrover sheet that someone kindly sent to me.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7881 ![]() ![]() ![]() |
Thanks for the info….
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 754 ![]() ![]() |
From my own experience on a 4.4 TDV8 I know that it will cut the engine but it does give a brief warning with what feels like a misfire. Switching off and restarting seems to reset things but not for long (minutes not days)
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16329 ![]() ![]() ![]() |
There is also a TSB available to explain the issue with the fuel pump wiring in the saddle tank and the car running out at 1/4 tank still showing on the gauge... |
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 ![]() ![]() |
I can state for certain that my (now departed) 2010VSE 3.6 worked perfectly well with the fuel gauge cable fault inside the tank as I drove it like that for a few months without any issues. there was no warning on the dash other than the needle reading zero fuel. 2010 VSE [Roger] |
