Home > Technical (L322) > Wont allow ignition key to turn
Bobin Vogue
United Kingdom 2007 Range Rover Vogue TDV8 Baltic Blue
My RR TDV8 has a problem which prevents the ignition key entering/turning. I have discovered that if I disconnect the battery and then reconnect it the problem goes away....ie key turns as normal. Switch off key out....same problem.
Any help or pointers gratefully accepted. Bob
Post #605850 7th Sep 2021 4:05pm
Hopefully some clues here -
https://www.fullfatrr.com/forum/topic56317.html
Post #605851 7th Sep 2021 4:30pm
Bobin Vogue
Thanks Alistair........I will let you know how I get on! Bob
Post #606014 9th Sep 2021 10:12am
RJPotts
Does the ignition lock on a 2007 vehicle work the same way as the earlier vehicle? (Just with the lock in a different place)
If so then this might be an easy fix: Youtube - Bens Garage - Range Rover Key Won't Turn
Post #606018 9th Sep 2021 10:25am
vs322
Greece 2004 Range Rover HSE 4.4 V8 Java Black
RJ,
Yes, it is the same, at least up to 2008 for sure. My employer's is a 08 Supercharged and had the same happen to him last month. He only was able to get it fixed a couple days ago at the cost of 700€ with the goldcar chip bypass method.
Ironically, mine got stuck again yesterday after 1 year. Ben's video is gold. The rubber mallet + WD40 combo worked a treat. I hadn't done anything to it when it first happened last year; was just a hiccup.
This morning I took off the column shroud and noticed that some spanner wielding primate had already been there before. The ECU box is full of scars an there's a cover plate corner broken off...Of course the primate's brain could only go that far because adding some oil would require some elevated functionality of abstract thinking...This kept it going for 2 years or more, can't know exactly how long, with just that intermediate hiccup. I hope I still caught it early on. If not, my local (now) indy can get it fixed properly with 350€ on a short notice. But at the moment, I'd rather spend this money doing more important things on the car...
Post #606157 11th Sep 2021 5:43am
