Home > Technical (L322) > Leaking F/R/H Spring
RRRob
United Kingdom 2004 Range Rover Vogue Td6 Cairns Blue
I have a leaking front R/H air spring.
I am capable of changing one myself and I have a diagnostic tool to deflate the spring safley etc.
Should I just change the one or is it better practice to change both front air springs at the same time.
Is the original part made by Delphi ?
Post #65711 25th May 2011 1:03pm
rob, tilemanvogue has just fitted one ,might be worth a pm to him.
http://www.fullfatrr.com/forum/topic6059.html
Post #65713 25th May 2011 1:17pm
stu
United Kingdom 2012 Range Rover Vogue TDV8 Orkney Grey
in my opinion, you should always as good practice change things in pairs. i haven't done it on the FF yet as i haven't had it long enough....(touch wood)
but i did it on my Disco and as you say it's not too bad a job. i kept the good one as a spair, cos you never know when you will need one. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #65716 25th May 2011 1:41pm
pretlove
i only changed the one on mine as the other side looked well....also i was told it tends to be the drivers side front that goes all the time alltough they didnt have an explination as to why....but all in all a very easy job "RANGEISM WILL NOT BE TOLERATED"
Post #65742 25th May 2011 4:29pm
DeltaC
United Kingdom 2003 Range Rover Vogue 4.4 V8 Buckingham Blue
Firstly, originals are Delphi.
I replaced both fronts a couple of weeks ago because the shock absorber is an integral part of the assembly.
Fairly straightforward job.
Post #65750 25th May 2011 6:24pm
There is a company in the US that does the replacement bags so it's a bit cheaper. Have a look round rangerovers.net/forums
Post #65797 25th May 2011 10:22pm
RRRob
Thanks for the advice Very Happy
Have ordered a pair of struts today along with track rod ends , anti roll bar link and a full set of discs,pads and sensors.
Post #65914 26th May 2011 6:05pm
tilemanvogue
England 2004 Range Rover Vogue 4.4 V8 Alveston Red
Hi Rob
Where did you order your parts from. I purchased my strut from Island 4x4 cost was 249.99 +vat best price around. My strut was caused by a stone or the like cutting the bag. Only changed drivers side as the other was perfectly ok. Yes easy to replace just had trouble with bolts that connect to hub, they were stuck solid. Discovery 3.9
Range Rover 4.6 HSE 1998
L322 Range Rover Vogue 4.4 2004
Post #65954 26th May 2011 10:18pm
SteveMFr
Site Sponsor
The maker of the replacement airbag alone is Arnott in Florida. The 2 replacement bags cost $400 or about the same amount as one replacement strut (GBP243) retail. In addition, though, you need to add a minimum of 1 hour to r&r the airbags on the old struts, so to compare you are realistically looking at about GBP175/side with just the Arnott bags (and old shocks) vs. GBP245/side with new OEM struts.
I have the Arnott airbags on my RR - they are good quality, but if the Delphi struts would have been available at that price a year ago, I would've gone with those.
You don't even need to deflate the system to change the struts: drop to access height and then jack the car up. The very small residual pressure - if any - can easily be let out by cracking a line or 2.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #65996 27th May 2011 10:31am
you could go this way and replace with coil springs...
http://www.arnottindustries.com/part_LAND_...id125.html
Post #66000 27th May 2011 10:58am
RRRob
Stan that defeats the object of a RR me thinks.
I wonder where you would stand with insurance if you changed to coils as the L322 has never had them therfore they wouldn't be manufacturer type approved.
I bet the insurance would say yep but that will be megga bucks !!!
Post #66029 27th May 2011 1:19pm
i suppose it does rob, but for a permanent 'fix' it could be viable...
Post #66031 27th May 2011 1:21pm
RRRob
it would certainly be cheaper Sad
Post #66032 27th May 2011 1:23pm
SteveMFr
Site Sponsor
Ugh. No, castrating a RR is not the way to go.
Yes, coils are somewhat cheaper - the air suspension needs attention (maintenance) every 5-7 years. The advantages are much greater than the drawbacks tho.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #66036 27th May 2011 1:31pm
RRRob
Are the rear air spring more "relaible" than the front ? or should I expect them to be giving up the ghost anytime soon ?
2004 TD6 123,000 Miles
Post #66041 27th May 2011 1:54pm
