Home > Technical (L322) > Leaking F/R/H Spring
stu
United Kingdom 2012 Range Rover Vogue TDV8 Orkney Grey
i had this issue with my Disco 2 a few years ago. on the D2 only the rear end was air, but because they were seven seaters and the air supported the weight etc etc it was illegal if i am correct to convert to coils unless you removed the rear seats.
thats why most people who wanted a suspension lift, did the normal lift on the front, but put alloy spacers on the axle then the air bags and extended the sensor arms to keep everything in line. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #66068 27th May 2011 6:47pm
