Home > Maintenance & Mods (L322) > Fabulous Tool and so simple
Merchy
As for Dr Bob's 'sit on your arse' method, not too good on the side of the road during a downpour Rolling with laughter
Will make some for mine, as the older I get, the heavier the wheel seems to be Big Cry
Post #604102 18th Aug 2021 4:38pm
Weegie
Maybe he is sitting on a pile Shocked John
GAP iiD BT-Sold
Post #604127 18th Aug 2021 7:05pm
KurtVerbose wrote:
DrRob wrote:
Has anyone heard of the 2 leg method? Sit on your arse and put a leg either side of the wheel Mrs and then use a long pry bar to lever it up into place. Takes seconds.
I will give it a try.
I gave it a go. I didn't use a pry bar as I had enough inner thigh strength to lift it without.
I won't show you the pic of me trying the same technique with the Mrs.
Post #604459 22nd Aug 2021 3:38pm
