![]() | Home > Maintenance & Mods (L322) > Switching Off Adaptive Cruise Control |
RRDunc Member Since: 26 Feb 2020 Location: Leicestershire/Warwickshire border Posts: 517 ![]() ![]() ![]() |
Unfortunately not. You can reduce the sensitivity using the switch on the left of the steering column but it resets each time you turn the ignition off.
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
Have you an IID tool? If so, send Patrick an email asking if the CCF files could be manipulated? |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2554 ![]() ![]() ![]() |
ACC can be disabled by modifying the CCF. I went in the other direction by enabling ACC after adding the radar module, switches and modifying the CCF. |
Gunning Member Since: 28 Sep 2016 Location: Cornwall Posts: 234 ![]() ![]() ![]() |
Sorry to bring an old thread up. Is it possible to code out ACC and just have cruise on the l322? There didn’t seem to be a definitive 100% yes answer. 19 L405 4.4 AB + Disco3 pick up + 800BHP Rothmans 911
Yes, by removing the fuse for the radar unit and modifying the CCF. During my ACC retrofitI had to temporarily remove it and leaving the radar unit's fuse fitted caused errors as unexpected/unrecognised data. |
Thank you for your reply Graham, does it come up with a fault in the central dash when all switch off? 19 L405 4.4 AB + Disco3 pick up + 800BHP Rothmans 911
Thank you for your reply Graeme, does it come up with a fault in the central dash when all switch off? 19 L405 4.4 AB + Disco3 pick up + 800BHP Rothmans 911
No faults will occur provding the ACC parameters in the CCF aren't enabled. |
Very helpful thank you Graeme, one more question, I don’t have an id tool. Is this something a Landrover specialists could do? 19 L405 4.4 AB + Disco3 pick up + 800BHP Rothmans 911
A LR specialist's diagnostic tool may or may not be able to make the necessary changes (a LR dealer's diagnostic tool probably cannot) and the specialist may or may not know which parameters to change. I can look-up what parameters I changed to convert from CC to ACC. |
Here are IIDtool screen-shots of what I changed to enable ACC, with some parameter overlap between pictures, so selecting a non-adaptive option for each should do the trick.
