Home > Maintenance & Mods (L322) > Switching Off Adaptive Cruise Control
Sonearly
Not that happy with ACC and was wondering if this can be switched off to allow standard cruise control. Two reasons, firstly have a intermittent fault, Radar Sensor Blocked which disables totally use of cruise control, and secondly find it a bit too sensitive to surrounding traffic.
Post #603878 15th Aug 2021 10:31pm
RRDunc
England 2012 Range Rover Autobiography TDV8 Santorini Black
Unfortunately not. You can reduce the sensitivity using the switch on the left of the steering column but it resets each time you turn the ignition off.
Dunc. The life you have is the only one you'll get; make the most of it.
2012 4.4 TDV8 L322 Autobiography
2003 TD5 Oslo Blue D2 ES Premium Auto (with mods!)
Post #603879 15th Aug 2021 10:42pm
Have you an IID tool? If so, send Patrick an email asking if the CCF files could be manipulated? Thumbs Up
Post #603880 15th Aug 2021 10:47pm
GraemeS
ACC can be disabled by modifying the CCF. I went in the other direction by enabling ACC after adding the radar module, switches and modifying the CCF.
Post #603887 16th Aug 2021 2:24am
Gunning
England 2013 Range Rover Autobiography SDV8 Baltic Blue
Sorry to bring an old thread up. Is it possible to code out ACC and just have cruise on the l322? There didn’t seem to be a definitive 100% yes answer. 19 L405 4.4 AB + Disco3 pick up + 800BHP Rothmans 911
Previous RR:
ALOT
Post #659664 17th Mar 2023 5:24pm
GraemeS
Yes, by removing the fuse for the radar unit and modifying the CCF. During my ACC retrofitI had to temporarily remove it and leaving the radar unit's fuse fitted caused errors as unexpected/unrecognised data.
Post #659673 17th Mar 2023 8:00pm
Gunning
Thank you for your reply Graham, does it come up with a fault in the central dash when all switch off? 19 L405 4.4 AB + Disco3 pick up + 800BHP Rothmans 911
Previous RR:
ALOT
Post #659675 17th Mar 2023 8:17pm
Gunning
Thank you for your reply Graeme, does it come up with a fault in the central dash when all switch off? 19 L405 4.4 AB + Disco3 pick up + 800BHP Rothmans 911
Previous RR:
ALOT
Post #659677 17th Mar 2023 8:22pm
GraemeS
No faults will occur provding the ACC parameters in the CCF aren't enabled.
Post #659708 18th Mar 2023 3:31am
Gunning
Very helpful thank you Graeme, one more question, I don’t have an id tool. Is this something a Landrover specialists could do? 19 L405 4.4 AB + Disco3 pick up + 800BHP Rothmans 911
Previous RR:
ALOT
Post #659710 18th Mar 2023 5:10am
GraemeS
A LR specialist's diagnostic tool may or may not be able to make the necessary changes (a LR dealer's diagnostic tool probably cannot) and the specialist may or may not know which parameters to change. I can look-up what parameters I changed to convert from CC to ACC.
Post #659711 18th Mar 2023 5:51am
GraemeS
Here are IIDtool screen-shots of what I changed to enable ACC, with some parameter overlap between pictures, so selecting a non-adaptive option for each should do the trick.
https://www.fullfatrr.com/gallery/albums/u...2-33~0.png
https://www.fullfatrr.com/gallery/albums/u...3-00~0.png
https://www.fullfatrr.com/gallery/albums/u...7-27~0.png
https://www.fullfatrr.com/gallery/albums/u...7-36~0.png
Post #659712 18th Mar 2023 6:00am
