Home > Technical (L322) > Windscreen Washer Pump Replacement
RR2B
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Baltic Blue
Windscreen washer pump has failed, and as I'm paranoid about jacking up the vehicle looks as though I'll have to access the pump by the bumper removal route. Before I make a start, can anyone categorically confirm that the washer pump will be accessible after removing the bumper? Many thanks! 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #603620 12th Aug 2021 5:28pm
V8 Bob
Replaced my headlight washer pump prior to the last Mot I loosened the inner wheel arch on passenger side the pumps sit alongside each other attached to the back of the washer bottle. I would have thought removing the front bumper would be a much bigger and fraught job and probably requires removal of both front wheels and liners to gain access.
I followed you tube video this clearly shows the pumps on the back side of the bottle.
https://www.google.co.uk/url?sa=t&rct=...8fAlML8Chd 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #603656 12th Aug 2021 8:43pm
RR2B
Thanks V8 Bob. Did you remove the wheel or is there sufficient clearance to ‘peel back’ the liner at off-road height? 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #603657 12th Aug 2021 8:52pm
V8 Bob
I took off the wheel and used an axle stand to support the vehicle. Was a straight forward job. Have to unclog liner along bottom edge….clips have a centre pin that opens out the lugs.
https://www.ebay.co.uk/itm/264542098279
I bought the attached which helped 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Post #603665 12th Aug 2021 11:06pm
RR2B
Thanks for the info. I’ll have to get myself a decent trolley jack and axle stands, and strive to overcome my jacking paranoia! 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #603717 13th Aug 2021 4:49pm
Eddie 24065017
United Kingdom 2009 Range Rover Vogue SE TDV8 Stornoway Grey
Hi, I have exchanged the headlight washer pump there’s no need to raise the car. Turn the front wheels to full right hand lock. Then remove the front section of the near side wheel arch cover, the washer tank will then be visible with the three pumps located in the rear of it the headlight pump is the one on the extreme left. It is larger than the other two which are the front and rear screen respectively. All three are just an interference fit sealed to the plastic washer tank by rubber grommets. Be aware that when you remove the pump the contents of the washer tank will pour out of the opening best to have a bowl or similar to prevent washer fluid from squirting I’m the ground on which you’re lying. Obviously you need to disconnect the electrical connector and the small rubber pipe which goes to the headlight washer jets. Note the headlight pump is larger than the other two pumps as it is a high pressure pump. This procedure relates to a 2009 L322. I did this without removing the road wheel but did raise the suspension to off road. L/R procedure is to remove the front bumper which is a pain.
Post #604863 26th Aug 2021 6:13pm
SomersetRR
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Fuji White
2010-12 L322 Rear Washer Relay Location
Hi all
Re-posting this here because i inadvertently posted it originally on the wrong topic section.
Following on from the discussion above, I am really struggling to find the relay for the rear washer motor on my 2011 L322 Autobiography (5.0L SC Petrol). The wiring diagram (which was really difficult to find for the 2010-12 version) shows the front and rear washer relays in the central control box which i understand to be the fuse box behind the glove box which only has 3 relays in it for the cigarette lighters and audio system. In the 2002-2009 versions of the L322 the relays were behind the battery but in the 2010-12 version there is nothing behind the battery and in front of the battery is the ECU. Does anyone have any ideas? I have seen a couple of threads on here about the same thing but the question was never answered as far as i can see. I am pretty sure it is the relay that is caput rather than the washer motor because when i push the stalk back no power goes to the washer motor but i tried switching the front washer plug onto the rear washer motor, pulled the stalk forward and the rear motor pumped fine out of the rear jet.
Pulling my hair out trying to locate the relay so any insight would be appreciated.
Thanks in advance!
Post #605241 31st Aug 2021 9:34am
RR2B
Eddie 24065017 wrote:
Hi, I have exchanged the headlight washer pump there’s no need to raise the car. Turn the front wheels to full right hand lock. Then remove the front section of the near side wheel arch cover, the washer tank will then be visible with the three pumps located in the rear of it the headlight pump is the one on the extreme left..
Thanks - I did try but just couldn’t get my hand in far enough. Admitted defeat and entrusted the job to my local indie. 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #605829 7th Sep 2021 12:53pm
