![]() | Home > Off Topic > Draper Welder |
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 ![]() ![]() ![]() |
Anyone on here into welding. Looking at buying myself another welder after the shebeast stole my one as I need too weld the trailer up.
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 360 ![]() ![]() |
You'd get that something like just using jacks, timber and a big hammer, it just needs something heavy parking on it to counteract the lift.
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
Deleted |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1223 ![]() ![]() ![]() |
A big +1 on the above post. |
Cheers for the advice. I've got a friend who does welding so he's going too oversee the trailer side of it but as you said get some practise in which is pretty much the plan.
Snowy90 L322 Member Since: 24 Aug 2015 Location: Surrey Posts: 224 ![]() ![]() ![]() |
As said before that will straighten out, just need some secure fixings and work in each plain first ie horizontally and then vertically will come back.
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 ![]() ![]() |
Regarding the specific welder listed, I would not buy that. Poor duty cycle and only 4 power settings and it doesn't look like a euro torch either. Better off buying a better quality machine second hand. Bish.
Deleted |
Once you get your welding machine Bean, get some scrap bits and practice, practice, practice, that is the only way to gain some proficiency, having a mate to show you the ropes is good. |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1356 ![]() ![]() |
Lincoln bullet best stick welder ever made |
Think the esab rebel might be out of my price league mate at £1200 upwards 😆 |
Andra Member Since: 22 Sep 2015 Location: Scotland Posts: 83 ![]() ![]() |
If it's for occasional use , Rohr welders get thumbs up from highly experienced welders . Their small , I should say absolutely tiny and lightweight 140 and 160 amp arc welders get great reviews and cost way less than £100 . They have one which has arc leads and tig leads , just need to buy tungsten tips for the tig lead . Check them out for yourself . Folk say you don't need more than 140 amps for welding cars . Some reviewers say they work fine on 4mm , 6mm plate .
Cheers andra. That's good too know |
