Home > Off Topic > Draper Welder
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Draper Welder
Anyone on here into welding. Looking at buying myself another welder after the shebeast stole my one as I need too weld the trailer up.
Trailer that needs cutting and welding
See this online so wanted too see what people's thoughts are. Look too spend around £250 so if you know of anything better throw it out there
https://www.toolden.co.uk/p/draper-71095-2...NCEALw_wcB
Cheers chaps
Post #603484 11th Aug 2021 2:12pm
andygts
You'd get that something like just using jacks, timber and a big hammer, it just needs something heavy parking on it to counteract the lift.
Galv is horrible to weld, you'd have to grind it all back to fresh steel before welding then asthetically it will stand out afterwards probably more than a couple of ripples from attempting to straighten it out using brute force. Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #603490 11th Aug 2021 3:01pm
Bean19844
Andy
Unfortunately at the back of the damage its split open so it will need welding regardless so figured best way would be too get some fresh steel and weld a new piece straight in.
I'd like too get a welder as I wanna start practising. A few of the workshop mechanics mess around when we don't break the vehicles. Thought doing something like this might be pretty cool
Post #603535 11th Aug 2021 8:25pm
ur20v
A Trap
Deleted
Post #603579 12th Aug 2021 9:49am
Merchy
A big +1 on the above post. Thumbs Up
As for galvanised metal weld repairs,
Post #603581 12th Aug 2021 10:16am
Merchy
Looking at the trailer pics, I would cut that section off and weld in new steel as advised. If you are new to welding this may well be worth getting someone to weld it for you, you could do all the prep work yourself to keep costs down.
Oooopppsss, sorry for double post
Post #603582 12th Aug 2021 10:19am
Bean19844
Cheers for the advice. I've got a friend who does welding so he's going too oversee the trailer side of it but as you said get some practise in which is pretty much the plan.
Just need too find something that's suitable for most jobs
Post #603588 12th Aug 2021 10:59am
Snowy90 L322
United Kingdom 2004 Range Rover HSE Td6 Giverny Green
As said before that will straighten out, just need some secure fixings and work in each plain first ie horizontally and then vertically will come back.
If Galvanised watch for fumes when welding and if you use heat. Ideally grind off the galv, and use a galv primer before you paint.
Looks like its only the cross member, but check the chassis fixings/mounts may have cracked.
Then weld the split at the back or if too big plate as mentioned as wide as possible.
I have a Clarke 135T Mig in hindsight i should have gone bigger but its good upto 5mm steel, im ausre that Draper one will do the job and be fine for hobbying welding.
Good luck
Post #603593 12th Aug 2021 11:39am
bishbosh10
Regarding the specific welder listed, I would not buy that. Poor duty cycle and only 4 power settings and it doesn't look like a euro torch either. Better off buying a better quality machine second hand. Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #603595 12th Aug 2021 11:50am
ur20v
A Trap
Deleted
Post #603599 12th Aug 2021 12:14pm
Merchy
Once you get your welding machine Bean, get some scrap bits and practice, practice, practice, that is the only way to gain some proficiency, having a mate to show you the ropes is good. Thumbs Up
Post #603603 12th Aug 2021 1:37pm
dingg1
Lincoln bullet best stick welder ever made Cool
Would love to find one out here
Post #603605 12th Aug 2021 2:06pm
Bean19844
Think the esab rebel might be out of my price league mate at £1200 upwards 😆
Post #603655 12th Aug 2021 8:37pm
Andra
If it's for occasional use , Rohr welders get thumbs up from highly experienced welders . Their small , I should say absolutely tiny and lightweight 140 and 160 amp arc welders get great reviews and cost way less than £100 . They have one which has arc leads and tig leads , just need to buy tungsten tips for the tig lead . Check them out for yourself . Folk say you don't need more than 140 amps for welding cars . Some reviewers say they work fine on 4mm , 6mm plate .
They have mig welders also . Cheap and work great .
Post #606351 13th Sep 2021 12:25pm
Bean19844
Cheers andra. That's good too know
Post #606384 13th Sep 2021 8:29pm
