![]() | Home > Technical (L322) > Has the MOT Tester broken my car? |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 ![]() ![]() ![]() |
Hi All,
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16312 ![]() ![]() ![]() |
Completely agree with the above... However, if the tester did put your car on the rollers then this could easily be the cause of massive damage! I believe all MOT's have CCTV now? Can anyone confirm this? Does it give you any kind of readout on your MOT paperwork for brake readings? If it does then there is a BIG worry as obviously, we all know they cannot go on the test rig...
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 696 ![]() ![]() ![]() |
As usual, I stand to be corrected....but...I believe all 'NEW' MOT test centres are to be fitted with cctv & may not cover 'current' MOT test centres. When I say 'NEW' I think it only came into operation this year, I'm a bit sketchy about the timescale though. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Thanks all. Your point about CCTV Craig, reminded me that I have a dashcam!
Ahh ok… That makes sense ![]() |
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 ![]() ![]() ![]() |
If you got access I'd get the front wheel off and have a look yourself n see if you can see anything obvious that might be the issue. |
Quick update. They've had it up on the ramp and apparently the rear bolts on the new lower arms were loose. They think the shaker plate may have loosened them if they weren't done up properly in the first place.
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1214 ![]() ![]() ![]() |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
What damage would be done? My tester has tested all my 4x4 using the rollers, in 4x4 mode the wheels go in opposite directions so only the diffs are rotating. BMW i3 Electric Car 2012 Full Fat RR 4.4 TDV8 (now gone) 2006 VW Touareg 3.0 TDi V6 |
Anvil Member Since: 18 Jan 2019 Location: Dorset Posts: 140 ![]() ![]() |
Hi Craig, What's the story with the rollers? Is this because they are permanent 4wd? How would they test this on a FFRR? -Just a test drive? FFRR 4.2SC/KTM 990SMT Current and cherished. Honda Accord 2.4 Vtec touring. (Yeah, I know, think: Kids) Mitsubishi Pajero Evolution Nut-wagon. and a Buell XB12R TVR Griffith 5.0 (backed up with Vauxhall Carlton road barge for the weekly shop.) Honda Integra Type R DC2 Possibly the best drivers car. Ever. Mitshibishi FTO GPX MIVEC. Honda CRX Vtec Mk2 -NO, Not the del sol!!! Volkswagen Scirocco GT Mini 1275GT MG Midget (Heavily modified) I'm going to stop now..... |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7861 ![]() ![]() ![]() |
My tester drives in the car park at 20mph and brakes hard with a portable unit on the seat to measure braking force.
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 521 ![]() ![]() ![]() |
I believe it's called a Tapley Meter https://www.bowmonk.com/products/view/tapley-brake-test-meter but as said above, some more modern rollers have a 4wd mode. 2016 Skoda Octavia VRS Estate
jagracer Member Since: 14 Aug 2021 Location: Norfolk Posts: 113 ![]() ![]() ![]() |
Its worrying that Mot testers are still not aware of the problems of brake testing a 4wd vehicle. Testing on rollers will not do a Haldex rear axle any good at all, nor will putting on rollers for a hand brake load test. My local garage says that Mot testing a Tesla is a problem as well. Luckely most of the local testers still use Tapley Meters for 4wd vehicles. |
As everyone else has answered with a tapley meter sir 👍 |
