Home > Technical (L322) > Has the MOT Tester broken my car?
kooky_guy
Hi All,
I had an MOT test yesterday (which it passed), but on leaving the station, the vehicle felt 'wrong'. A bit further up the road it produced a loud clonk/crack noise from the front nearside when going over a bump. I put it down to the suspension being a bit unsettled after having being lifted, but it's continued to do it.
When changing from forwards to backwards (and vice versa), it often (but not always) makes a loud 'crack' sound from that area. Reversing on full lock gives a similarly worrying sound (which can be felt too) and it now seems to squeal a tyre when turning full lock.
It was doing none of these things prior to the test and has only very recently had both lower arms replaced.
The tester didn't seem to be very experienced, but I don't think he put it on the rollers (in fact I overheard a conversation about not being able to test the brakes on the rollers).
It's going in to another branch tomorrow to be inspected, but can anyone immediately suggest something that an inexperienced tester might have done that might have caused these symptoms to manifest? (Forewarned is forearmed and all that). I wanted to take it to my trusted indy, but they're rammed.
I need it fixed as I've got a family holiday coming up and it doesn't feel safe.
All the best 2010 4.4 TDV8 Vogue SE
Post #603422 10th Aug 2021 9:19pm
Merchy
At a GUESS, all I can think of is that the tester may have used a lever bar to see if any suspension joints / bushes have any wear in them, and could have damaged something. It could have been co-incidence, as I would not like to accuse anyone of something without proof, but situation does sound a bit fishy to me.
If he has used a lever he could have distorted the brake disc backing plate?
Post #603427 10th Aug 2021 11:12pm
Completely agree with the above... However, if the tester did put your car on the rollers then this could easily be the cause of massive damage! I believe all MOT's have CCTV now? Can anyone confirm this? Does it give you any kind of readout on your MOT paperwork for brake readings? If it does then there is a BIG worry as obviously, we all know they cannot go on the test rig...
Would you like me to interrogate my local tester tomorrow? I'm there for an MOT so can do it easily enough sir... Thumbs Up
Post #603428 10th Aug 2021 11:55pm
Fox889
As usual, I stand to be corrected....but...I believe all 'NEW' MOT test centres are to be fitted with cctv & may not cover 'current' MOT test centres. When I say 'NEW' I think it only came into operation this year, I'm a bit sketchy about the timescale though. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
Post #603431 11th Aug 2021 6:22am
kooky_guy
Thanks all. Your point about CCTV Craig, reminded me that I have a dashcam!
I've just been looking at the footage and it seems that he did the brake test in the car park, although he did seem to get stuck in the rollers when initially trying to get it onto the ramp right at the start. He was revving it quite a bit without it moving - I can't quite tell what was going on - he then reversed and took a run up to finally get it on the ramp.
Most of the footage just showing it with the engine running and the bonnet up so not particularly enlightening apart from those highlights.
Will see what they come up with this morning - they're not exactly LR specialists though. 2010 4.4 TDV8 Vogue SE
Post #603436 11th Aug 2021 7:03am
Ahh ok… That makes sense Thumbs Up
Post #603439 11th Aug 2021 8:41am
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
If you got access I'd get the front wheel off and have a look yourself n see if you can see anything obvious that might be the issue.
Post #603449 11th Aug 2021 9:35am
kooky_guy
Quick update. They've had it up on the ramp and apparently the rear bolts on the new lower arms were loose. They think the shaker plate may have loosened them if they weren't done up properly in the first place.
Slightly concerned that this has happened at all and also why the mot didn't pick it up!
All seems back to normal now though so all well that ends well.
Thank you for all your help.
Guy 2010 4.4 TDV8 Vogue SE
Post #603457 11th Aug 2021 10:33am
Merchy
Shocked With regards to the person(s) who fitted your new lower arms, personally I would go back there and 'HAVE WORDS' with them. I know we can all make mistakes, but that is very poor workmanship.
Luckily I have known my MOT testers for many years ( Family run business ) and I am allowed to get in the pit with the tester to see it all, ( With boiler suit on so Joe public think I work there ) a rare thing these days.
Glad you are already sorted and safe, with peace of mind on your holidays Thumbs Up
Post #603461 11th Aug 2021 10:56am
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
What damage would be done?
My tester has tested all my 4x4 using the rollers, in 4x4 mode the wheels go in opposite directions so only the diffs are rotating. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #603741 14th Aug 2021 4:35am
Anvil
Hi Craig,
What's the story with the rollers? Is this because they are permanent 4wd? How would they test this on a FFRR? -Just a test drive? FFRR 4.2SC/KTM 990SMT Current and cherished.
Honda Accord 2.4 Vtec touring. (Yeah, I know, think: Kids)
Mitsubishi Pajero Evolution Nut-wagon. and a Buell XB12R
TVR Griffith 5.0 (backed up with Vauxhall Carlton road barge for the weekly shop.)
Honda Integra Type R DC2 Possibly the best drivers car. Ever.
Mitshibishi FTO GPX MIVEC.
Honda CRX Vtec Mk2 -NO, Not the del sol!!!
Volkswagen Scirocco GT
Mini 1275GT
MG Midget (Heavily modified)
I'm going to stop now.....
Post #604660 24th Aug 2021 2:00pm
mjdronfield
My tester drives in the car park at 20mph and brakes hard with a portable unit on the seat to measure braking force.
He only has rollers for a single axle. I think if he put the RR on it, the diffs would lock an the car would drive out the rollers into his office…..
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #604664 24th Aug 2021 2:48pm
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
I believe it's called a Tapley Meter https://www.bowmonk.com/products/view/tapley-brake-test-meter but as said above, some more modern rollers have a 4wd mode. 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #604668 24th Aug 2021 4:40pm
jagracer
United Kingdom 2011 Range Rover Vogue 4.4 V8 Zermatt Silver
Its worrying that Mot testers are still not aware of the problems of brake testing a 4wd vehicle. Testing on rollers will not do a Haldex rear axle any good at all, nor will putting on rollers for a hand brake load test. My local garage says that Mot testing a Tesla is a problem as well. Luckely most of the local testers still use Tapley Meters for 4wd vehicles.
Post #604670 24th Aug 2021 4:47pm
Hi Craig,
As everyone else has answered with a tapley meter sir 👍
Post #604672 24th Aug 2021 4:54pm
