Home > Technical (L322) > L322 tdv8 3.6 in fuel tank test 2010 version |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 730 |
The pump should run when the ignition is turned on but only long enough to prime the line/build up pressure.
23rd Aug 2021 8:05pm |
Landmark Member Since: 22 Nov 2020 Location: Hampshire Posts: 118 |
Great thanks for super quick reply. So if I loop over relay I should here it run. Does that sound feasable. Tbo I don't ever remember hearing it run .Are they super quiet. |
23rd Aug 2021 8:16pm |
I've made a schrader valve 1 bar test rig up to see what the low pressure is which I believe is .5 bar or 7psi. |
23rd Aug 2021 8:18pm |
They are pretty quiet
23rd Aug 2021 8:28pm |
Yep that makes sense going to have a good play this afternoon. I will report back. |
24th Aug 2021 6:10am |
OK tested pump and pump is working. Dissconnected pipe from pump to filter housing and .5bar at filter end with good flow. Took pipe of outlet side of filter and filter outlet also good showing .5bar however small length of pipe going from schrader test point to high pressure pump has no pressure. Getting dark now so will have to continue tomorrow. |
24th Aug 2021 6:58pm |
