Home > General > What Did You Do In Your Full Fat Today
Page 358 of 380 <123 ... 357358359 ... 378379380>
batfink
2004 Range Rover Vogue 4.4 V8 Adriatic Blue
Replaced the broken bonnet release cable that just snapped by the handle which was lucky, so I could at least open the bonnet with a pair of pliers.
Not too bad to change using a length of electrical cable to use as a pull through for the new one.
Post #657865 26th Feb 2023 3:39pm
WDRR
United Kingdom 2008 Range Rover Vogue TDV8 Santorini Black
Replaced lower tailgate cable straps. Spuld be a 10 minute job but...
Note the offside bolt head was stripped and rusted in.
some remedial action re rust protection was required but all fine in the end. 10 minute job became a 30 minute job plus the ti.e to get the extra stuff and tool to repair. ... All good now Willie
2008 TDV8 Santorini Black
Post #657868 26th Feb 2023 5:02pm
Danb_220_2019
United Kingdom 2012 Range Rover Vogue SE TDV8 Fuji White
Yesterday fitted a replacement silver trim strip to the upper tailgate and replacement rear mudflaps from PowerfulUK as one of the originals was missing (and neither side had been fitted correctly in the first place. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Previous V8s: BMW 645Ci, P38 4.6, P38 4.0, Merc CL500
Previous others: Honda x1, Volvo x7, Rover x6, BMW x6, Ford x1, Mercedes x2, Skoda x3, VW x2, Renault x2, Citroen x1, Mazda x3, Nissan x1, Audi x3, Kia x1, Fiat x4, Subaru x3, Austin x2, Triumph x2, Jeep x2, Hyundai x2, Lexus x1, Mitsubishi x1, Saab x2... and some others I've forgotten!
Post #658353 3rd Mar 2023 3:49pm
Goldstar
2011 Range Rover Autobiography TDV8 Stornoway Grey
Bit of a wash and brush up followed by new rear brake pads. Will need new discs soon but already had the pads. 45 mins to do the offside (blooming wear indicator wire is a pig) and 10 mins on the nearside Smile Dec 2021- 2010 Facelift TDV8 4.4 AB in Stornoway Grey.
Post #658360 3rd Mar 2023 5:24pm
JayGee
Fitted new steering outer track rod ends after garage told me they couldn't align it properly as there was too much play in the joints. Didn't need a ball joint splitter in the end as a couple of 'taps' with 4lb lump hammer did the job but needed a lot of heat on the threaded section to free the threads. Alignment booked on Monday. 2012 TDV8 Vogue (L322)
Post #658440 4th Mar 2023 1:23pm
Floopy
Took the family out for the day.
 2006 L322 Vogue SE 4.2
Post #658566 5th Mar 2023 6:23pm
Gremlin500
Sailed through its 3rd MOT today with no advisories Thumbs Up
Mr. Green “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #658619 6th Mar 2023 11:13am
cupples8267
Scotland 2016 Range Rover Vogue SE SDV8 Santorini Black
Changed the lower control arms. One side ball joint popped out easily, the other side needed heat with oxy-acetalyne, then the steel insert in the alloy hub came out after much pressure and hammering. I then pressed the steel insert off the old control arm in a 25T press. Then pressed the insert back into the hub, and installed the new control arm. Bloody pain of a job.
Post #658691 6th Mar 2023 9:05pm
Goldstar
Replaced front left height sensor (thank you @advancedfactors)
Had the dreaded “suspension fault” suddenly, strangely after jet washing the arches. GAP told me zero voltage at the front left and hey presto a change of sensor sorted it after I tried taking it off (3 times) and using contact cleaner and hoping that might sort it.
Getting the old one off the bracket was a bitch, ended up grinding off the top of each set screw as they just turned in the old sensor. I knew it was a problem so ordered the new set screws as well, by the way the bracket is a LR only part at £173 plus VAT!!! I was very careful with the grinding disc. Dec 2021- 2010 Facelift TDV8 4.4 AB in Stornoway Grey.
Post #659511 15th Mar 2023 9:39pm
caymanblack
Gave her a clean. Cool
 overfinch modified
Post #659801 19th Mar 2023 4:38pm
damonky
United Kingdom 2011 Range Rover Vogue 4.4 V8 Orkney Grey
Found and fixed a rattling side intake vent with a glue gun 😂
2011 4.4 TDV8 Vogue
Post #659810 19th Mar 2023 7:30pm
Gremlin500
Treated my FF to its first wash with this:
Embarassed Managed to blow off the little lock cover drivers door although the jet was at least a foot away,
then found it to be loose on reattachment, so heated it with my little heatshrink gun and squeezed the sides together so it was slightly concave, hey presto “CLICK!” and it was perfect again, phew!
Apparently, its very common, so be careful jetwashing! “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #659857 20th Mar 2023 9:53am
Ajmngn
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Today I fixed a B1A76-15 Fuel Sender No.2 Fault
Quite impressed with myself today. I managed to troubleshoot and fix a fault with my fuel gauge reading incorrectly as a result of a Fuel Sender Fault. This is not uncommon from what I can ascertain and affects Disco 3 & 4, RRS and FFRR. Anyway, long story short, it took about 2 hours to learn by doing, and was free!!
Full details here if you're interested...
https://www.fullfatrr.com/forum/topic66408.html Andy
2010 4.4TDV8 Vogue SE in Santorini Black with Ivory interior
2017 Audi SQ5 3.0 V6T Quattro in Volcano Red
2001 Audi Allroad 2.5 TDI manual with low-range in Highland Green. Currently SORN whilst undergoing some serious restoration!
Post #660070 22nd Mar 2023 8:40pm
mgrover
Replaced my rear shocks with the aerosus ones, already had done front.
Did bags too.,
night and day difference. the rears were completely shot.
currently due to adaptive fault am guessing its in "hard" mode. but thats already like a million times better than the bouncing that was going on. Its actually a sport Sad
Not anymore, 4.4 TDV8 now Very Happy
Post #660106 23rd Mar 2023 10:31am
Merchy
The dreaded MOT day again today......WooHoo...passed Very Happy
Now off outside as it's not raining, to change wiper blades as advised, already in my stock of parts and to fit my newly arrived Powerful UK reversing lights as in the photo Kevinp posted (cheers Kev) like the look of these and better than the single candle power of the originals. Then I will not have to ride the brake when I need light for reversing. Whistle
Post #660270 24th Mar 2023 4:40pm
