Home > General > What Did You Do In Your Full Fat Today
Page 340 of 381 <123 ... 339340341 ... 379380381>
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
Fitted the now infamous EGT sensor to bank 2 on the TDV8 4.4 2011 TDV8 Vogue SE
Post #606323 13th Sep 2021 7:30am
vs322
Greece 2004 Range Rover HSE 4.4 V8 Java Black
MOT day today...Passed with flying colours Thumbs Up
Post #606448 15th Sep 2021 9:33am
RRDunc
England 2012 Range Rover Autobiography TDV8 Santorini Black
Vacuumed the inside and washed the outside of it. Knackered now.
Dunc. The life you have is the only one you'll get; make the most of it.
2012 4.4 TDV8 L322 Autobiography
2003 TD5 Oslo Blue D2 ES Premium Auto (with mods!)
Post #606759 18th Sep 2021 8:29pm
vs322
Steering column lock refurbishment
Front + rear diff oil change
Transfer case oil change
XYZ switch replacement
A pillar exterior trim replacement
Post #606997 21st Sep 2021 6:32pm
JayGee
1st day of ownership - thorough interior clean, front wheel balance and tracking (one tyre is out of round), fitted my mobile phone holder, ordered GAP IID tool, ordered Bovee 1000 blue tooth streaming input for the 30pin ipod socket, compiled a long list of jobs......
Woke up at 4am in a cold sweat when the reality dawned on me that I now own an L322 Shocked Shocked Shocked Shocked 2012 TDV8 Vogue (L322)
Post #607037 22nd Sep 2021 8:28am
Happydaze
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
Yesterday I fitted a complete used Westfalia towbar and electrics. All went well.
Today I checked the electrics and initially thought there was a problem with the caravan fridge etc circuitry, lights etc being fine (phew!) Turned out there is more electrickery in the caravan electrics than I thought would ever be the case! All good, but best to have an understanding of the manual beforehand! Embarassed
Having continued non-communication despite several reminders with Luxury Land Rover Upgrades, aka Luke Cooper, aka Discodevil in respect of non supply of goods for in excess of £350 for 4 weeks now. Not a peep from him. Beginning to fear the worst and will be contacting credit card company shortly. Shame as I need a replacement reversing camera!
Chris
Post #607072 22nd Sep 2021 4:51pm
just a reminder to members that this is a 'one' post thread so please dont discuss or reply to posts as this spoils the thread..thanks. ... - .- -.
Post #607112 23rd Sep 2021 11:05am
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Used mine to start help smarten the garden up with carrying slabs around after the shebeast decided that she needed too take these with her
Post #607121 23rd Sep 2021 2:01pm
DrRob
New front discs and pads courtesy of Advanced Factors and Glenrands. Long overdue Shocked Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #607123 23rd Sep 2021 2:42pm
RRDunc
Pollen, oil and both air filters changed along with 9.5 litres of C1.
Post #607289 25th Sep 2021 12:28pm
Weegie
Had left front strut fitted. Right front was done two or three weeks ago. John
GAP iiD BT-Sold
Post #607299 25th Sep 2021 2:28pm
colalowe
United Kingdom 2012 Range Rover Autobiography TDV8 Buckingham Blue
Removed dash and repaired radio.
Fourth time lucky!
The two buttons under my volume knob have never worked, so I decided to have a go at fixing it.
First two times I couldn’t get the dash off to get at the radio, third time I managed to get it all out and found the circuit board had popped off inside so thought I’d fixed it. No such luck!
Bought a new front and had a go today, removed everything and swapped the parts over for the fronts and now my buttons work. Very Happy
Interestingly I have a dual view screen! The replacement fronts were £150 but the single view screen was only £80, I bought the single view and swapped over the buttons for the dual view as it appears underneath they are both the same fronts except for the writing on the right hand buttons, both circuit boards appear identical.
Post #607310 25th Sep 2021 6:14pm
JayGee
Connected up and paired my Gap IID tool and ran a scan and lots of codes but all very minor and old apart from; P040D-00 (2F) Exhaust gas recirculation temperature sensor A - circuit high
Seems a common issue and not something to worry about but have set up the live data to keep an eye on it and DPF soot levels
As the car came with 255/55 R20's I've tried to adjust some settings to get the speedo and other associated displays to read more like a normal car but it's work in progress - rolling radius for the ABS in mm and wheel size ( in inches) are 2 values that need changing. Bit alarming when the process is completing even if I was expecting it.
Was going to take it out for a run tomorrow but with the current panic buying I think I'll save my remaining diesel for work use. 2012 TDV8 Vogue (L322)
Post #607311 25th Sep 2021 6:28pm
JMC
Plugged in the trickle charger without even unlocking the car (via my home-made cable to the white 7-pin tow electrics) and took the motorbike out instead. Couple of hundred miles later on two wheels and I returned to find the FFRR is still there and looking good. Result!! Whistle The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #607321 25th Sep 2021 8:53pm
Wogger
England 2010 Range Rover Vogue TDV8 Orkney Grey
Nothing, not enough diesel in it, and no fuel on the forecourts around here, country’s gone mad !!! Banging Head
Post #607325 25th Sep 2021 9:55pm
