Home > General > What Did You Do In Your Full Fat Today
Page 338 of 377 <123 ... 337338339 ... 375376377>
Ron Greevar
United Kingdom 2011 Range Rover Vogue 4.4 V8 Galway Green
Got back from our first long trip in our new to us MY11 4.4 TDV8 Vogue. We had a very enjoyable week in Ceredigion/Pembrokeshire.
Door to door we did 758 miles and our Galway Green beauty did not miss a beat - mind you I don't think I have ever taken so much car first aid stuff with me, iCarSoft LR2.0, oil, PAS fluid, coolant, the Sprinter jack, wheel change rods etc etc!
The old girl is now touching 130k miles so I did have some butterflies beforehand but am more than pleased with the way we wafted along with 32-42 average mpg showing most of the time up hill and down dale.
And of course Galway Green is such an unusual colour - so how do you explain not one but two identical Rangies coming the other way within 10 minutes in deepest darkest Pembs?
Ron Thumbs Up
Post #599624 4th Jul 2021 3:42pm
vs322
Greece 2004 Range Rover HSE 4.4 V8 Java Black
Gave the old girl a bubble bath and a wax. Cleaned the interior as well.
My back is killing me but was worth it...
Post #599631 4th Jul 2021 5:54pm
LT
Drove around a dairy farm.
“Green Ice”. Fortunately that field was flat.
Post #599634 4th Jul 2021 6:36pm
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
Took it for a full 4 wheel alignment at an indy that is new to me but sadly not local. Needed to give it a good run as it's not turned a wheel since December so seemed like a good idea, albeit a 280 mile round trip Rolling with laughter 2011 TDV8 Vogue SE
Post #599756 6th Jul 2021 6:24am
LT
Had a little play on Salisbury Plain. I took the same c.3-4 mile route I did in a new Defender 110 on Monday. Both shod with “road” tyres. Both enormously capable, you’d need some seriously challenging terrain for the superior off road ability of the new Defender to shine.
Post #600103 8th Jul 2021 10:27pm
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Finally got around to curing the minor leak from my radiator drain plug.
Looks a bit like this...
That one is from the diesel models and I have been told a new one is not available for the SC.
My o ring kit did not have the right size so borrowed a kit from a friend who is a professional and had a far superior kit than mine. It still took several attempts so for any one else who has a similar problem with the sc then the rings are 6.1mm x 9.3mm
Too be extra sure I also put an ring on the head of the tap insert and tightened very carefully to ensure that i did not damage the o ring.
So far the problem is cured.
David Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #600105 8th Jul 2021 11:27pm
matlandy
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Spent the day on recovery duty’s at Goodwood Festival Of Speed with Sussex 4x4 Response
Post #600228 10th Jul 2021 7:39pm
CongoBoy
South Africa 2005 Range Rover Vogue SE 4.2 SC V8 Java Black
Aux Connectivity
I originally planned to do this to connect my iPhone for phone use but reflashing the Bluetooth module with my GAP OBDII tool sorted that.
A quick fix to stream music via Bluetooth from my phone. I originally did this fix in my D£ and hardwired it.
I just used a 90-degree male connector and went through the console to the inside and then used the power plug inside.
I think this has been shown a few times on the forum.
 2005 FFRR SC Java Black with Overfinch Exhaust (UK)
2008 D3 HSE Stornoway Grey (UK)
2008 D3 HSE Izmir Blue (ZA/Zimbabwe)
1995 D1 300 Tdi (Zimbabwe)
Post #600765 15th Jul 2021 1:56pm
Barmybrummie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Fitted new overfinch steering wheel. Absolutely love it.
Post #600948 17th Jul 2021 1:39pm
Barmybrummie
Fitted the electronics for the paddle shift. I now have fully working paddle shift, feels fantastic. Took me 2 hours, not bad for a beginner. Thought I would I have a go myself seeing as I had some time off.
Post #601031 18th Jul 2021 12:00pm
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
steam cleaned engine bay today and a drop of shearlack
first time outside since i got it 3 months ago to steam clean engine bay and a bit of engine glaze that i got 25 years ago still good this stuff will last for a couple of months its that old the label has dropped of . so i have now finished in the engine bay fingers crossed it will be nice to use it not long now
 new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #601055 18th Jul 2021 6:27pm
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Sure traditionally the belt is supposed too be on the car.... looks like the pulley as dead so that's the next job on Tuesday
Post #601065 18th Jul 2021 7:42pm
Weegie
Not today yesterday, had an oil and filters change. Had only done 4000 miles since last service 2020. John
GAP iiD BT
Post #601515 22nd Jul 2021 6:50pm
b348xyx
I replaced the Air Con condenser yesterday and had kwik Fit re-gas the Aircon. added 2ml of UV die, 10ml of AC OIL incase I missed a leak but pressure tested and all good. 2003 Range Rover 4.4 Litre V8 - Adriatic blue
2003 Range Rover 4.4 Litre V8 -Maintenance History Click Here = http://www.fullfatrr.com/forum/topic39687.html
Post #601610 23rd Jul 2021 4:05pm
bigbo
Did a supercharger oil change, a very simple job made difficult by access problems. I will put some photos on "My Range Rover" soon. Range Rover 4.2 Supercharged 2006
MG TF 2003
Post #601662 24th Jul 2021 12:41am
