Home > General > What Did You Do In Your Full Fat Today
Page 292 of 378 <123 ... 291292293 ... 376377378>
Emperor Mong
Sold it!
New one arrives next week, hopefully.
Post #511855 12th Apr 2019 5:25pm
Gsxr1250dave
Swopped out the burnt solenoid contacks
Post #511895 12th Apr 2019 10:26pm
Danbhardy
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
Replaced the standard stereo that didn’t work for an aftermarket one. Original one didn’t work at all, but this new one works well if your deaf Smile cos it still has no sound!! But at least I have a display with the time on!
Post #511948 13th Apr 2019 3:45pm
Crasher242
Used Sport mode for the first time Thumbs Up Current
Vogue SE 4.4 SDV8
Previous highlights
Many Mini's!
Audi S8
Audi A6 Avant (the petrol guzzling Bi-turbo)
Subaru H6 3.0 Estate
Peugeot 406 Coupe V6
Audi 80 Quattro Sport
Post #511950 13th Apr 2019 4:24pm
TDV8_Tommy
Spain 2012 Range Rover Westminster TDV8 Baltic Blue
Painted the back box.
Took it back to bare metal and used BBQ paint, good for 600 degrees.
Completely changes the look of the car 😄
Oh, and fitted a new front prop to the P38, no more wobbles!
Double win today 👌
 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
1997 P38 2.5 DSE auto & 1998 P38 2.5 DT Manual
1988 Vogue 3.5 EFI - Manual, gone.
2004 Volvo C70 2.0T convertible, had since new.
2007 Mazda MX-5 2.0 Sport Roadster/Coupé, had since new.
2024 Mini Cooper S cabrio, JCW kit, 2.0, DCT auto
Post #511963 13th Apr 2019 6:06pm
Rude
United Kingdom 2010 Range Rover Vogue SE TDV8 Alaska White
Cleaned 1,000,000,000 tar spots off it. The joy of white...
Post #512675 20th Apr 2019 6:10pm
mpirie
Replaced both rear discs, pads and shims on my Westie.
Looking at what came off was embarrassing Rolling Eyes
Mike
Post #512706 21st Apr 2019 8:20am
Rude
I’d love to be able to do maintenance like that. I’ve no clue though...!!!!!
I’ll stick to making it look pretty!
Post #512752 21st Apr 2019 4:27pm
Crasher242
Dropped the rear seats as flat as they will go, and then loaded the rear with "junk" from our sheds ready for a tip to the tip tomorrow.
Well, it is supposed to be a working car!
Just hope I can get rid of the dusty smell, and the millions of spiders that are likely to find their new enclosure more comfortable than the shed Smile Current
Vogue SE 4.4 SDV8
Previous highlights
Many Mini's!
Audi S8
Post #512771 21st Apr 2019 6:44pm
SoggyBottoms
United Kingdom 2007 Range Rover Vogue Supercharged Zambezi Silver
spent over an hour researching how to replace my reversing camera only to discover it was just caked in this Saharan sand / dust and a wet wipe sorted it
Post #513068 24th Apr 2019 4:58pm
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
Up on the ramp, for oil change. Drainage container emptied and back on the stand for the last bit from the difficult to get to second sump nut...as the last bt dribbles in to container, knock it off the stand and watch as it hts the floor in slow motion. B@ll@cks !! Half a bag of soak it up later, job done. Change every 6 thous and its always like water.
Post #513094 24th Apr 2019 9:20pm
Gsxr1250dave
Past its mot
Post #513170 25th Apr 2019 4:51pm
Beninfrance
France
Cut the grass in our field today, picture was from last summer but you get the idea. 2002 Range Rover TD6
2010 Range Rover 3.6TDV8
Post #513179 25th Apr 2019 6:15pm
mpirie
Replaced the starter motor on my 2012 Westie.
Replaced the locking wheel key with one supplied by Dan.....fortunately, I remembered the code letter from the old one, so a word of wisdom to all owners, take note of the code letter and keep it safe in case you need to replace it!
Mike
Post #513403 27th Apr 2019 6:32pm
Ian Donkin
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
Finished off three days 'fettling' of the front end - removed the 'orrible headlight grills (they were genuine LR - now in the bin along with the rears), rebuilt side-light units with stainless bolts for easier removal next time, replaced all headlight hardware with new clips and stainless bolts, fitted new air con condenser ready for a re-gas on Monday, fitted new bonnet release cable between the two catches, adjusted bonnet stops and started to give the bonnet a thorough clean with clay bar, G3 compound and paint restorer to remove a lifetime of oxidisation from it. There's actually a really deep silver hidden under the surface contamination! 2011 Range Rover Vogue SE 4.4 TDv8
Post #513415 27th Apr 2019 9:21pm
