Home > General > What Did You Do In Your Full Fat Today |
pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218 |
vdisco |
10th Jan 2015 2:23pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3237 |
Did second gearbox oil and filter change. The first filter I put in a few weeks ago wasn't original equipment. I wasn't happy with it and so, as I was doing a second oil change, decided to change for Filtran OE. Much more impressive. The pattern filter didn't seem to sit in properly whereas the Filtran clicks into place. Well maybe not "clicks" but it does go in very positively. At my age it's quite a change to have something go in positively. John
10th Jan 2015 4:47pm |
jakebullet64 Member Since: 28 May 2014 Location: Wolverhampton Posts: 259 |
evening all,
10th Jan 2015 6:31pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Christmas has come and gone, I was lucky to receive a Karcher K4 pressure washer and snow foam attachment.
11th Jan 2015 6:00pm |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 |
Having some new lower arms and ball joints to fit, I thought better get on with it today before weather turns for the worst again. 1 arm done, drivers side, both ball joints need changing but that near side arm will not budge off the ball joint
11th Jan 2015 7:32pm |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 |
Bought some L405 wheels and placed an order for some smoked fog lights from PowerfulUK. l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
11th Jan 2015 8:23pm |
Would quite like a "snow foam" paint job, very Mad Max / Zombie Apocalypse / post nuclear .
11th Jan 2015 8:29pm |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1655 |
Very mundane Sunday. SWMBO and I drove to Dunelm in Worcester brought two rugs - drove home.
11th Jan 2015 8:59pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
I did my rear diff oil change. Out with old brownish fluid, in with synthetic red fluid. Tip- it's difficult to squeeze last half litre from bottle. I used two 1 litre pots and got about 1.5 litres in decanting under the car. . Also, remove top filler to make sure it undoes before draining.you need a set of drain removing plugs as the key is quite a big one unlikely to be in you Allen key range. Getting more oil to do front. Job took 15mins I think. On stands |
11th Jan 2015 10:43pm |
Is the snow foam method a sort of no sponge needed way to wash, or is it a no bucket needed, ie you use your sponge on an always wet car etc. I always have issues racing round my car to keep it wet, I do it in 4 sections. The snow foam might be a method I would try. I have a larches 5 series. I thought karchers just made lines in long term grime. There's no such thing as an easy car wash, is there. |
11th Jan 2015 10:52pm |
markcaughey Member Since: 03 Nov 2014 Location: Glasgow Posts: 316 |
Snow foam is designed as a pre was to remove 90% loose dirt/grime. Then you can safely wash the car using 2 bucket method without moving dirt around in the paintwork.
11th Jan 2015 11:20pm |
Agree with Mark, it is not the be all and end all. I followed "advice" (I read somewhere...?) and put the snow foam on a dry car, whereas I would normally wet the car before any soapy stuff. Rinsed/jet washed off after @ 7 minutes, no streaks.
12th Jan 2015 12:08am |
changed the headlight bulbs for 6000k ones. now my side lights look too white in comparison anyway happy with the end result as i always felt the 4300k just looked like halogen bulbs
12th Jan 2015 1:04pm |
Stuntman Member Since: 27 Dec 2014 Location: Norfolk Posts: 67 |
Driven from Stevenage to home in norfolk, currently just fixing my new a bar on and some rear light guards.
12th Jan 2015 3:22pm |
