Home > General > What Did You Do In Your Full Fat Today
Page 172 of 379 <123 ... 171172173 ... 377378379>
pld118
Thumbs Up vdisco
Post #304061 10th Jan 2015 2:23pm
Weegie
Did second gearbox oil and filter change. The first filter I put in a few weeks ago wasn't original equipment. I wasn't happy with it and so, as I was doing a second oil change, decided to change for Filtran OE. Much more impressive. The pattern filter didn't seem to sit in properly whereas the Filtran clicks into place. Well maybe not "clicks" but it does go in very positively. At my age it's quite a change to have something go in positively. Embarassed John
GAP iiD BT
Post #304075 10th Jan 2015 4:47pm
jakebullet64
United Kingdom 2003 Range Rover Vogue 4.4 V8 Santorini Black
evening all,
Changed the driver's door lock / actuator.
gummi pfledged the doors
stripped and rebuilt the eas compressor
topped up the coolant
quick Hoover and clean inside
that's enough for one day. Razz 2003 Range Rover Vogue 4.4 on Gas
1961 88" 2.25 diesel - George
Gone - 1997 3.9 V8i Discovery - Burt
Post #304091 10th Jan 2015 6:31pm
Stuntman
United Kingdom 2002 Range Rover HSE Td6 Zambezi Silver
Drove from Norwich to the nec for the Motorsport shoe, then drove to Gloucester to se klf400 from this parish and pick up a bull bar and light guards, the drove home,
Probably 500 miles all in.
Then I'm off to hitchin at 7am tomorrow morning
Post #304141 10th Jan 2015 11:04pm
Played with new Cleaning Toys today!
Christmas has come and gone, I was lucky to receive a Karcher K4 pressure washer and snow foam attachment.
Given I haven't washed the car since August, seemed a good time to try them out. I purchased some of this to go with it:
As you can see, a dirty FFRR!
Only snow we are likely to see this year. Followed the instructions and used @ 30% solution in the 1/2 litre container, which just about did the whole car.
Not a bad result, although the pressure washer had to shift the really ingrained dirt, and to get it really clean I'll have to go over it by hand, but not bad, and a lot less effort!
Post #304232 11th Jan 2015 6:00pm
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
Having some new lower arms and ball joints to fit, I thought better get on with it today before weather turns for the worst again. 1 arm done, drivers side, both ball joints need changing but that near side arm will not budge off the ball joint Big Cry
Going to garage to sort it, bloody green ovals, don't you just hate them at times!
Joe 90 your ff looking good clean Thumbs Up If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #304253 11th Jan 2015 7:32pm
verydisco
Bought some L405 wheels and placed an order for some smoked fog lights from PowerfulUK. Thumbs Up l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #304262 11th Jan 2015 8:23pm
Would quite like a "snow foam" paint job, very Mad Max / Zombie Apocalypse / post nuclear Laughing .
Post #304265 11th Jan 2015 8:29pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Very mundane Sunday. SWMBO and I drove to Dunelm in Worcester brought two rugs - drove home.
OMG middle age has arrived!! 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #304274 11th Jan 2015 8:59pm
johnboyairey
I did my rear diff oil change. Out with old brownish fluid, in with synthetic red fluid. Tip- it's difficult to squeeze last half litre from bottle. I used two 1 litre pots and got about 1.5 litres in decanting under the car. . Also, remove top filler to make sure it undoes before draining.you need a set of drain removing plugs as the key is quite a big one unlikely to be in you Allen key range. Getting more oil to do front. Job took 15mins I think. On stands
Post #304300 11th Jan 2015 10:43pm
johnboyairey
Is the snow foam method a sort of no sponge needed way to wash, or is it a no bucket needed, ie you use your sponge on an always wet car etc. I always have issues racing round my car to keep it wet, I do it in 4 sections. The snow foam might be a method I would try. I have a larches 5 series.
I thought karchers just made lines in long term grime. There's no such thing as an easy car wash, is there.
Post #304302 11th Jan 2015 10:52pm
markcaughey
Scotland 2006 Range Rover Vogue 4.4 V8 Buckingham Blue
Snow foam is designed as a pre was to remove 90% loose dirt/grime. Then you can safely wash the car using 2 bucket method without moving dirt around in the paintwork.
Although if the cars is relatively clean I give it a quick jet wash then snow foam and run round and sponge the car down with a rinse bucket.
For me personally snow foam alone is now use, as I said it leaves it 90% clean Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #304313 11th Jan 2015 11:20pm
Agree with Mark, it is not the be all and end all. I followed "advice" (I read somewhere...?) and put the snow foam on a dry car, whereas I would normally wet the car before any soapy stuff. Rinsed/jet washed off after @ 7 minutes, no streaks.
Just pleased that the Karcher kit made snow foam that stuck on the car, as I had also read many users had been disappointed with the performance. For me couldn't have been better, was like a snow machine at the Olympics Smile
Will get the sponge out next time Smile .
Post #304322 12th Jan 2015 12:08am
markcaughey
changed the headlight bulbs for 6000k ones. now my side lights look too white in comparison Big Cry anyway happy with the end result as i always felt the 4300k just looked like halogen bulbs
4300k bulbs
6000k bulbs
Post #304423 12th Jan 2015 1:04pm
Stuntman
Driven from Stevenage to home in norfolk, currently just fixing my new a bar on and some rear light guards.
I might get around to moving the mid to the glove box tonight
Post #304453 12th Jan 2015 3:22pm
