Home > Maintenance & Mods (L405) > AirCon Service Rip Off ??? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35274 |
its not part of the 48k mile service so although its showing an 'amber' i would get the diagnosis double checked and go with the cheapest quote. ... - .- -.
6th Aug 2021 11:59am |
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1017 |
Which dealer?
6th Aug 2021 12:30pm |
forever Member Since: 06 Oct 2015 Location: Oxted Posts: 319 |
Coulsdon, and my bad its the 64k service so the big one, needs a new compressor as well but that should be under warranty |
6th Aug 2021 1:14pm |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 732 |
As the compressor can't be changed without removing/refilling the gas I can't see how they can justify charging anything for gas if the compressor is under warranty? |
6th Aug 2021 1:59pm |
Martin2 Member Since: 15 Jun 2020 Location: Northamptonshire Posts: 766 |
Isn’t it amber just because of time rather than there being any real need to get it done?
6th Aug 2021 2:48pm |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 768 |
There is no time period to get the air conditioning gas refilled. If it ain't broke and it's performing adequately, there's no need to do anything. Kev
6th Aug 2021 3:03pm |
I know that, but every main dealers I’ve used still tries it on! MY23 Panamera E-Hybrid
6th Aug 2021 3:09pm |
Therein lies the problem Kev
6th Aug 2021 3:41pm |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 |
Deleted |
6th Aug 2021 4:18pm |
Deleted |
6th Aug 2021 4:24pm |
Absolutely, servicing should be done in line with the manufacturers service schedule and it is silly not to.
6th Aug 2021 6:09pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
I hate main dealers and this post proves it Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
6th Aug 2021 7:04pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1181 |
Best way to check the compressor function is to take the pressures from the ports when operating, if OK, then leave well alone. That check for leaks, if it still blowing nice and cold, chances are that you will not find a leak. |
6th Aug 2021 9:17pm |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1340 |
Nothing to service on an aircon system gents, sealed system, nothing can get in or out, only needs looked at when it doesn't work properly, usually due to a leak of refrigerant. |
7th Aug 2021 9:01am |
