Home > Maintenance & Mods (L405) > AirCon Service Rip Off ???
forever
So my RR is in for a 48k service, and they have listed as amber a aircon service @ 450.00!!! I think they are taking the Censored unless i am missing something? My local kwick fit will do it for 125, apparently thats more than normal due to the more expensive gas the RR uses...
Thoughts?
Post #602998 6th Aug 2021 12:40pm
its not part of the 48k mile service so although its showing an 'amber' i would get the diagnosis double checked and go with the cheapest quote. ... - .- -.
Post #603001 6th Aug 2021 12:59pm
Andy S
United Kingdom 2015 Range Rover Vogue SE SDV8 Aintree Green
Which dealer?
I’d challenge the price quoted and point out the lower quote.
Post #603005 6th Aug 2021 1:30pm
forever
Coulsdon, and my bad its the 64k service so the big one, needs a new compressor as well but that should be under warranty
Post #603011 6th Aug 2021 2:14pm
cass
As the compressor can't be changed without removing/refilling the gas I can't see how they can justify charging anything for gas if the compressor is under warranty?
Post #603015 6th Aug 2021 2:59pm
Martin2
Isn’t it amber just because of time rather than there being any real need to get it done?
VW did the same on my wife’s car when it was in for service last time, as it was 3 years old they put it down as an amber issue on the inspection. It’s blowing really cold, so I’m not getting it done as it would feel like a waste of money.
But in this case, I agree that they should be paying for it as part of the compressor change. Definitely. But maybe they haven’t linked the two things and it’s a standard ‘revenue opportunity’ that they’ve put on the paperwork? MY23 Panamera E-Hybrid
MY19 SDV8 Autobiography - Sold
Post #603017 6th Aug 2021 3:48pm
knwatkins
There is no time period to get the air conditioning gas refilled. If it ain't broke and it's performing adequately, there's no need to do anything. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #603022 6th Aug 2021 4:03pm
Martin2
I know that, but every main dealers I’ve used still tries it on! MY23 Panamera E-Hybrid
Post #603024 6th Aug 2021 4:09pm
knwatkins
Therein lies the problem Wink Kev
Post #603026 6th Aug 2021 4:41pm
ur20v
A Trap
Deleted
Post #603030 6th Aug 2021 5:18pm
ur20v
A Trap
Deleted
Post #603031 6th Aug 2021 5:24pm
knwatkins
Absolutely, servicing should be done in line with the manufacturers service schedule and it is silly not to.
Where does the manufacturer specify to service the air conditioning system every 2 years and replace the receiver drier?
It certainly is not in the service sheets located on the wiki here. Kev
Post #603047 6th Aug 2021 7:09pm
DrRob
I Censored hate main dealers and this post proves it Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #603049 6th Aug 2021 8:04pm
Merchy
Best way to check the compressor function is to take the pressures from the ports when operating, if OK, then leave well alone. That check for leaks, if it still blowing nice and cold, chances are that you will not find a leak.
Post #603057 6th Aug 2021 10:17pm
dingg1
Nothing to service on an aircon system gents, sealed system, nothing can get in or out, only needs looked at when it doesn't work properly, usually due to a leak of refrigerant.
Post #603083 7th Aug 2021 10:01am
