Home > Maintenance & Mods (L322) > Westfalia tow bar armature differences
Steve RR
Scotland 2011 Range Rover Vogue SE TDV8 Fuji White
Hello,
Does anyone know the difference between a pre 2006 and the later Westfalia tow bar armature frame? I think I remember reading somewhere that they are different at the front end but could be modified.
Needing one for a 2011 322 but looks to be more chance of getting an earlier one.
Cheers 2011 Disco 4
2011 TDV8 FFRR
4.6 P38 Autobiography x2
300Tdi county 110
Too many late Classic RR to count
Bowler Tomcat Smile
Post #602930 5th Aug 2021 6:56pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
I think you could find it`s something to do with the exhaust hangers?
Post #602934 5th Aug 2021 7:35pm
Yep exactly that... Exhaust hangers moved on later models sir Thumbs Up
Post #602959 6th Aug 2021 1:30am
coopss
I’ve been looking as well - do we know which year the hangers changed? 1995 4.6 v8, green/tan (long gone)
2005 4.8iS X5, blue/black
2011 4.4 tdv8, black/black (gone)
2003 3.0d X5, Oxford green/black/manual
2021 p575 SVR, BR green/vintage tan
Post #602961 6th Aug 2021 6:07am
Steve RR
Thanks chaps, that’s good so it’s not a structural change.
I believe the part number changed at 2006.
Cheers. 2011 Disco 4
2011 TDV8 FFRR
300Tdi county 110
Bowler Tomcat Smile
Post #602967 6th Aug 2021 9:09am
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
You can fit an earlier version easily by grinding off the exhaust hanger from the strengtheners and simply bolting on with the bar and car itself -- the old hangers you can leave on, they don't get in the way. Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #602972 6th Aug 2021 9:20am
BMW to Ford ownership so circa 2006/7
Post #602978 6th Aug 2021 9:45am
Japseroony
England 2019 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Can-Tech-Craig - I have sent you a PM re something else Thumbs Up "UNDERSTEER" ----is when you hit the fence with the front of the car.
"OVERSTEER" ------is when you hit the fence with the rear of the car.
"HORSEPOWER" ----is how fast you hit the fence.
"TORQUE" -----------is how far you take the fence with you.
Post #603020 6th Aug 2021 3:56pm
Davidmudley
So am I right in understanding that you can grind off this red line section so that the exhaust hanger mount can be used on pre-2007 RR?
I've got the pre-2007 armature that I am mounting on my 2011 RR and trying to work around the exhaust hanger differences. Thanks
 Current: Range Rover L322 4.4tdv8, Porsche 911 (996) Carrera 2, BMW 535d Touring, Skoda Fabia, BMW S1000XR
Post #627151 28th Mar 2022 3:29pm
Bushy30
Hi David,
Almost -- that bracket goes all the way under the rest of the strengthener -- you need the entire bit of angle, including the hole to bolt through with the old type bar set.
Turn that over and you'll see the full piece of angle, like this:-
Previous: -
Post #627157 28th Mar 2022 5:01pm
Davidmudley
Fab, thanks Bushy30. Going to give it a go tonight 🤞 Current: Range Rover L322 4.4tdv8, Porsche 911 (996) Carrera 2, BMW 535d Touring, Skoda Fabia, BMW S1000XR
Post #627158 28th Mar 2022 5:10pm
