Home > Technical (L322) > 2011 4.4 tdv8 poor running.
GraemeS
Is P0088 the only fault code?
It might be an idea if you have an IIDTool or other suitable diagnostic tool to monitor the crankshaft position sensor in case the sensor is faulty as it's a known failure point in earlier 4.4 engines.
Post #602538 1st Aug 2021 8:56pm
PeteT80
I maybe wrong but does blanking and a delete on the EGR on these engines mess up the DPF settings?
Post #602539 1st Aug 2021 8:58pm
daveturbo
But if the Crank sensor was Faulted surely it would not start. Mercedes AMG w207
E class Cabriolet
Overfinch L322 4.4 tdv8
1987 sierra rs cosworth 3 door white.
1985 escort rs turbo series one.
1992 sierra sapphire 4x4 cosworth red
1993 sierra sapphire cosworth 4x4 silver
1993 sierra sapphire cosworth 4x4 white
1995 ducati 916sp.
Post #602545 1st Aug 2021 9:52pm
GraemeS
Quite a few instances reported on this forum where the engine either momentarily doesn't run properly or intermittently stops without recording any faults. The sensor part number was superseded in later engines suggesting that the sensor was improved.
Post #602549 2nd Aug 2021 2:17am
daveturbo
poor running
It starts every time just will not rev up,until warm. Mercedes AMG w207
E class Cabriolet
1995 ducati 916sp.
Post #602561 2nd Aug 2021 8:37am
GraemeS
Have you determined if diagnostics can show the fuel pressure? I'd be monitoring a few sensors using my IIDTool on cold start but if no joy then on every drive until a significant better or worse event occurs.
Post #602575 2nd Aug 2021 11:27am
daveturbo
poor running
I have a Snapon Solus Edge,going to try some fuel pressure readings tonight,will have to Google what the pressures should be. Mercedes AMG w207
E class Cabriolet
1995 ducati 916sp.
Post #602584 2nd Aug 2021 12:36pm
GraemeS
From the WSM - the pressure control valve.
https://www.fullfatrr.com/gallery/albums/u...0valve.pdf
Note the last paragraph.
Post #602627 2nd Aug 2021 9:03pm
daveturbo
poor running
All of those have been changed. I took the Injectors, Fuel Rails and Pipes off Last night and sent them off to be cleaned and checked,will update when its back together. Think i might replace the Fuel Pressure Control Valve in case the new one is faulted,many thanks for your Help. Mercedes AMG w207
E class Cabriolet
1995 ducati 916sp.
Post #602648 3rd Aug 2021 9:25am
daveturbo
Update. 5 Injectors Faulted, so new ones ordered. Mercedes AMG w207
E class Cabriolet
1995 ducati 916sp.
Post #602728 3rd Aug 2021 8:28pm
daveturbo
Fitted new Injectors and Exactly the Same.
Will only rev up after running for about ten minutes ,got the same codes p0193-17 and p0088-17,also if the fuel rail sensor is plugged in it will not start. Mercedes AMG w207
E class Cabriolet
1995 ducati 916sp.
Post #602954 5th Aug 2021 9:37pm
GraemeS
Not good and implying that the HPFP itself may be the cause. I wonder if it's had a dose of petrol and driven until damage was done to the pump and injectors.
It might still be worth trying another regulator.
Have you confirmed that the return pipe isn't blocked?
Post #602960 6th Aug 2021 2:25am
daveturbo
poor running
I have booked into Land Rover to see if they can Diagnose it, there is the original Regulator in the car i might try it back in.
i will also check the Return pipe,Cheers Buddy. Mercedes AMG w207
E class Cabriolet
1995 ducati 916sp.
Post #602997 6th Aug 2021 11:31am
kevinp
You know like on carburettor cars they needed a choke to increase the air/fuel ratio to be able to rev when cold? I don't know which part of these engines does a similar thing but I know until it reaches normal temperature some sensor tells it to hold on to gears longer. I thought I'd read something about the glow plugs doing something similar. It just sounds it needs more fuel until it's warmed up. Engine temperature sensor?
Post #603004 6th Aug 2021 12:26pm
daveturbo
Cheers Kevin,all temp sensors reading correct,air butterfly flap also working fine,not sure if the air change over valve is working though. Mercedes AMG w207
E class Cabriolet
1995 ducati 916sp.
Post #603034 6th Aug 2021 4:47pm
