![]() | Home > Technical (L322) > 2011 4.4 tdv8 poor running. |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1280 ![]() ![]() ![]() |
Do you know if the fuel filter has been changed? When I changed my air filters I forgot to plug in one of the MAF sensors and it ran similar to yours. One could be faulty. Obviously check the four hoses on the plenum chamber. |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2575 ![]() ![]() ![]() |
The secondary turbo changeover/isolation valve only opens under higher engine load and not until around 2500 rpm. However its lever should be able to be moved in the direction of moving the rod into the vacuum chamber although the spring is quite strong. Vacuum provided to the chamber by bypassing or energising the solenoid valve (one of the solenoids at the top front of the engine) at idle will open the valve.
daveturbo Member Since: 11 Nov 2012 Location: county durham Posts: 107 ![]() ![]() ![]() |
Tried MAF sensors and MAP sensor still the same, looks like poss High Pressure Fuel Pump. Mercedes AMG w207
Presumably the fuel system has been bled. |
JNC Member Since: 23 Feb 2020 Location: UK Posts: 293 ![]() ![]() ![]() |
Has the EGR system been taken out? |
Yes the fuel System is bled, the egr has a blacking plate fitted. Mercedes AMG w207
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7877 ![]() ![]() ![]() |
I’m assuming the EGRs are mapped out the engine management system too? I don’t believe you can blank them without issue, unless you do other things.
I have been told the EGR was deleted from the map ,but im still getting a EGR fault showing. Mercedes AMG w207
I know they aren’t the easiest things to get to, but what about removing the blanking plates. If it’s mapped out the EGRs won’t open anyway.... has it always done this? Is there anything else changed recently?
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4325 ![]() ![]() ![]() |
I'd personally get it back to standard and have the egr blanking removed ttoally Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Would a failing high pressure fuel pump not give me these Symptoms. Mercedes AMG w207
4040 Member Since: 19 Sep 2019 Location: Cornwall Posts: 44 ![]() ![]() ![]() |
I though I read somewhere that the egr can’t be removed on the 4.4s |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 754 ![]() ![]() |
+1 for DrRob's suggestion, trying to find a fault on something that has been "upgraded" by a previous owner is always going to be a ball ache |
