Home > Technical (L322) > 2011 4.4 tdv8 poor running. |
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 214 |
I maybe wrong but does blanking and a delete on the EGR on these engines mess up the DPF settings? |
1st Aug 2021 8:58pm |
daveturbo Member Since: 11 Nov 2012 Location: county durham Posts: 107 |
But if the Crank sensor was Faulted surely it would not start. Mercedes AMG w207
1st Aug 2021 9:52pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2523 |
Quite a few instances reported on this forum where the engine either momentarily doesn't run properly or intermittently stops without recording any faults. The sensor part number was superseded in later engines suggesting that the sensor was improved. |
2nd Aug 2021 2:17am |
It starts every time just will not rev up,until warm. Mercedes AMG w207
2nd Aug 2021 8:37am |
Have you determined if diagnostics can show the fuel pressure? I'd be monitoring a few sensors using my IIDTool on cold start but if no joy then on every drive until a significant better or worse event occurs. |
2nd Aug 2021 11:27am |
I have a Snapon Solus Edge,going to try some fuel pressure readings tonight,will have to Google what the pressures should be. Mercedes AMG w207
2nd Aug 2021 12:36pm |
From the WSM - the pressure control valve.
2nd Aug 2021 9:03pm |
All of those have been changed. I took the Injectors, Fuel Rails and Pipes off Last night and sent them off to be cleaned and checked,will update when its back together. Think i might replace the Fuel Pressure Control Valve in case the new one is faulted,many thanks for your Help. Mercedes AMG w207
3rd Aug 2021 9:25am |
Update. 5 Injectors Faulted, so new ones ordered. Mercedes AMG w207
3rd Aug 2021 8:28pm |
Fitted new Injectors and Exactly the Same.
5th Aug 2021 9:37pm |
Not good and implying that the HPFP itself may be the cause. I wonder if it's had a dose of petrol and driven until damage was done to the pump and injectors.
6th Aug 2021 2:25am |
I have booked into Land Rover to see if they can Diagnose it, there is the original Regulator in the car i might try it back in.
6th Aug 2021 11:31am |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1236 |
You know like on carburettor cars they needed a choke to increase the air/fuel ratio to be able to rev when cold? I don't know which part of these engines does a similar thing but I know until it reaches normal temperature some sensor tells it to hold on to gears longer. I thought I'd read something about the glow plugs doing something similar. It just sounds it needs more fuel until it's warmed up. Engine temperature sensor? |
6th Aug 2021 12:26pm |
Cheers Kevin,all temp sensors reading correct,air butterfly flap also working fine,not sure if the air change over valve is working though. Mercedes AMG w207
6th Aug 2021 4:47pm |
