![]() | Home > Maintenance & Mods (L322) > Genuine parts v pattern. |
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 ![]() ![]() ![]() |
Tbh mate if your buying pattern parts for a range rover you probably shouldn't own one in the first place. I'm not saying everything has too be genuine but certain things really shouldn't be replaced with pattern crap |
Here here... |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1293 ![]() ![]() ![]() |
That's why I wanted a genuine one. I bought a pattern lower tailgate strut once. It was worse than the original!!! |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
if i go non genuine i tend to stick to OE spec parts. some pattern parts are a joke 2012 Vogue 4.4 TDV8 - Current
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 ![]() ![]() ![]() |
No name parts are crap.
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 ![]() ![]() |
even pattern part suspension bolts are poorer quality. They look the same before they're fitted but generally rust has formed on them within a couple of months.
its actually "hear hear" Craig, your response seemed non-genuine ![]() |
coopss Member Since: 21 Apr 2018 Location: Hampshire Posts: 281 ![]() |
I’ve recently gone full OEM on a few parts
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 774 ![]() ![]() ![]() |
They were manufactured by Delphi, more specifically, the Chassis Division of Delphi. BWI subsequently acquired that division so BWI are now the OEM. Kev
PaulM Member Since: 08 Mar 2015 Location: Warwickshire Posts: 190 ![]() ![]() ![]() |
I’ve only ever used genuine parts. Question I have, is what’s really the difference between genuine & OEM? Is the OEM the same as genuine just without the Land Rover packaging? 2004 RR 4.4 V8 Autobiography |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 705 ![]() ![]() ![]() |
OEM used to mean Original Equipment Manufacturer & meant the original supplier of the part in question.
My understanding of OEM is the part is the same as originally supplied to RR in this case minus the branding. so if Bilstien for example supplied the rear shock it will probably have LR branding on it and come in a LR box. the same shock can be had from Bilstien but just branded by Bilstien not LR.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8529 ![]() ![]() ![]() |
It's as Pawl says
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1232 ![]() ![]() ![]() |
I do not always automatically buy LR branded parts. I look at what is available and who the makers are, and their reputation, as well as pricing.
