Home > Off Topic - Other Cars > Range Rover Evoque
Jayk69
Range Rover Evoque
Hi All,
my sister in law has treated herself to a 2012 evoque.
the electric drivers seat has an issue moving forward and back. it does move but not in a single movement you have to keep pushing the button. so you push and hold the button the seat move a little then stops then you have to release and push again.
same when you push the memory seat button the seat moves a little then stops and you have to push again.
any suggestion would be great 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #601466 22nd Jul 2021 12:12pm
in case you dont get an answer here you could peruse the evoque forum ,
http://babyrr.com/forum/ ... - .- -.
Post #601467 22nd Jul 2021 12:23pm
JamesD
United Kingdom 2016 Range Rover Vogue TDV6 Corris Grey
Sounds like bad contacts on the switch which keep interrupting the motor, you could try and take the switch apart or buy a used one off eBay. 2021 L405 Vogue D300
2016 L405 Vogue 3.0TDV6 (Sold)
Post #601469 22nd Jul 2021 12:45pm
JamesD
As you mention it also does not work on the memory button it could be another thing....If the seat has lost its calibration it can limit the inputs on the switch as it does not know what position in the seat is in (hence why it stops and starts). You can try and reset this by running the seat in all motions from end to end so it gets to each stop point, make sure you do this when you are running or have good charge else the meetings won't be recorded by the memory module. If that does not resolve it it could be a bad position sensor or just the switch as I mentioned. There is a sensor on the seat track which records the position, if this fails then it will limit movement to prevent damage. If you can find it you could unplug and clean the contacts on this also....as they are under the seat the wires could have been damaged by something being forced under the seat. 2021 L405 Vogue D300
Post #601470 22nd Jul 2021 12:54pm
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
This is also an issue if someone has retro fitted electric memory seats. Check on the Discovery forum for this issue.
HTH
Ivan 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #601474 22nd Jul 2021 1:06pm
Jayk69
thanks all.
i will run a scan on the car to see if there are any faults registered then go and try to re-set them. 2012 Vogue 4.4 TDV8 - Current
Post #601556 23rd Jul 2021 6:17am
