Home > Off Topic - Other Cars > Range Rover Evoque |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35326 |
in case you dont get an answer here you could peruse the evoque forum ,
22nd Jul 2021 12:23pm |
JamesD Member Since: 21 Jan 2013 Location: Worcestershire Posts: 203 |
Sounds like bad contacts on the switch which keep interrupting the motor, you could try and take the switch apart or buy a used one off eBay. 2021 L405 Vogue D300
22nd Jul 2021 12:45pm |
As you mention it also does not work on the memory button it could be another thing....If the seat has lost its calibration it can limit the inputs on the switch as it does not know what position in the seat is in (hence why it stops and starts). You can try and reset this by running the seat in all motions from end to end so it gets to each stop point, make sure you do this when you are running or have good charge else the meetings won't be recorded by the memory module. If that does not resolve it it could be a bad position sensor or just the switch as I mentioned. There is a sensor on the seat track which records the position, if this fails then it will limit movement to prevent damage. If you can find it you could unplug and clean the contacts on this also....as they are under the seat the wires could have been damaged by something being forced under the seat. 2021 L405 Vogue D300
22nd Jul 2021 12:54pm |
IGP Member Since: 09 Jul 2020 Location: Malvern Posts: 287 |
This is also an issue if someone has retro fitted electric memory seats. Check on the Discovery forum for this issue.
22nd Jul 2021 1:06pm |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
thanks all.
23rd Jul 2021 6:17am |
