![]() | Home > Maintenance & Mods (L322) > Gearbox oil - If it's not broke, don't fix it? |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1355 ![]() ![]() |
I'd change oil and filter, wouldn't reset adaptations... |
aja500 Member Since: 15 Oct 2017 Location: South East Posts: 826 ![]() ![]() ![]() |
I didn't know that was an option, or even what they are - Are they some kind of gearbox settings |
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 395 ![]() ![]() ![]() |
if you are looking at doing a 100k i would take it and have a new filter and full flush replace all old oil with new so £350/ £400 but it is better than paying for a rebuild down the road £2.000 / £3.500 could be more new vehicle purchase
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 982 ![]() ![]() |
You’re right to be cautious. A drain & refill will refresh the fluid without risking friction shock, especially if your solenoid adaptions are already compensating for worn solenoids. Don’t use anything other than Lifeguard Fluid 6 and a genuine IBS Filtran sump pan/filter.
Thanks for the advice Phil and also for your thoughts oggy.
The worse that can happen is that, as a result of changing the fluid, you change the friction characteristics of the fluid. The controller monitors the shift times and, if it detects that these have changed, it will try to alter the fill pressure and fill time adaptions for the particular PWM solenoids involved in the shift to bring the shift time back to acceptable levels.
That's great, thanks for the accurate and detailed guidance - Would you expect a good independent LR specialist to know not to reset the adaptions, or should I make this clear?
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1789 ![]() ![]() |
Change it early, change it often |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
Deleted |
RR2B Member Since: 04 Aug 2020 Location: Rowlands Castle Posts: 254 ![]() ![]() ![]() |
Any opinions on Millermatic?
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
+1 no brainer. I do mine every 30.000 miles max l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l Current RANGE ROVER Vogue 4.4L SDV8 - 2013 - Indus Silver, on Almond. RANGE ROVER Vogue 4.4L V8 - 2002 - ex-2003 G4 Challenge Event Vehicle, Stage 3: Australia RANGE ROVER HSE 4.4L V8 - 2004 - one-of-one Overfinch RANGE ROVER P38a 4.0L V8 - 1999 - ex-2000 TReK Event Vehicle: South Africa Previous: RANGE ROVER Vogue 4.4L TDV8 - 2012 - RANGE ROVER 3.6L TDV8 x3 - RANGE ROVER Td6 x1 - RANGE ROVER Classic 3.5L V8 x1 |
Deleted |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3153 ![]() ![]() ![]() |
When I bought my Supercharged in January the oil level was low in the box. When draining it I got less then a litre out.
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 753 ![]() ![]() |
When a man with the knowledge and experience of RRPhil says only use Lifeguard fluid then using anything else to save a few quid sounds a bit risky to me |
