Home > Maintenance & Mods (L322) > Gearbox oil - If it's not broke, don't fix it?
aja500
United Kingdom 2019 Range Rover Autobiography 5.0 SC V8 Aruba
I have a 2006 (2007MY) L322 4.4 Vogue V8 Petrol, which has the later Jaguar engine and 6 speed gearbox. This is actually a very rare car as most people when buying new back then, went for either the 3.6 TDV8, or 4.2 Supercharged variants.
I've owned the car for 8 years and wouldn't swap it for anything - It's covered 105,000 miles and it drives absolutely beautifully. My question is, do I now change the gearbox oil and filter or not? Am I opening a can of worms?
It did have 3 litres of transmission fluid oil added 3 years ago at 78,000 miles and the sump replaced following a leak, so it has had some new fresh oil added but it looks like they didn't change all of the oil, or the filter.
So do I change the oil and filter to protect the car for another 100k miles, or leave it well alone to avoid creating problems?
Your thoughts and opinions would all be greatly appreciated.
Many thanks in advance
Post #599806 6th Jul 2021 4:16pm
dingg1
I'd change oil and filter, wouldn't reset adaptations...
Post #599807 6th Jul 2021 4:22pm
aja500
I didn't know that was an option, or even what they are - Are they some kind of gearbox settings
Post #599839 6th Jul 2021 7:47pm
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
if you are looking at doing a 100k i would take it and have a new filter and full flush replace all old oil with new so £350/ £400 but it is better than paying for a rebuild down the road £2.000 / £3.500 could be more new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #599843 6th Jul 2021 7:58pm
RRPhil
You’re right to be cautious. A drain & refill will refresh the fluid without risking friction shock, especially if your solenoid adaptions are already compensating for worn solenoids. Don’t use anything other than Lifeguard Fluid 6 and a genuine IBS Filtran sump pan/filter.
Phil
Post #599847 6th Jul 2021 8:24pm
aja500
Thanks for the advice Phil and also for your thoughts oggy.
It's not about the money and I do have other cars, so the 100k miles I will potentially add, will be over the next 15-20 years.
I suppose if I do change the transmission oil / filter / sump pan etc, what's the worse that can happen?
And in this event, is it irreversible, or can anything always be rectified?
Post #599849 6th Jul 2021 8:47pm
RRPhil
The worse that can happen is that, as a result of changing the fluid, you change the friction characteristics of the fluid. The controller monitors the shift times and, if it detects that these have changed, it will try to alter the fill pressure and fill time adaptions for the particular PWM solenoids involved in the shift to bring the shift time back to acceptable levels.
The problem is that older 6HP26s are plagued with solenoid problems which mean that the solenoids are already set at the extremes of the adaption range and can go no further. You then risk excessive clutch slip and permanent damage to the transmission.
For this reason, as has already been stated, you should never reset the adaptions following a fluid change or you could trash your transmission. This would only happen if one or more of the solenoids was faulty, though, and you could determine this first by reading off the adaption fill pressure and fill time values before resetting them.
Phil
Post #599852 6th Jul 2021 9:16pm
aja500
That's great, thanks for the accurate and detailed guidance - Would you expect a good independent LR specialist to know not to reset the adaptions, or should I make this clear?
I use these guys. They've been working on Land Rovers locally for more than 45 years:
https://www.groombridgesussex.co.uk/
Many thanks again for your help
Post #599854 6th Jul 2021 9:27pm
Mikey
Change it early, change it often Thumbs Up
Post #599857 6th Jul 2021 10:05pm
ur20v
A Trap
Deleted
Post #599888 7th Jul 2021 8:37am
RR2B
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Baltic Blue
Any opinions on Millermatic?
https://www.millersoils.co.uk/products/millermatic-atf-8-speed/ 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #599899 7th Jul 2021 10:34am
verydisco
+1 no brainer. I do mine every 30.000 miles max l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #599900 7th Jul 2021 10:46am
ur20v
A Trap
Deleted
Post #599901 7th Jul 2021 10:48am
dhallworth
When I bought my Supercharged in January the oil level was low in the box. When draining it I got less then a litre out.
I replaced my solenoids, the bridge seal and the 4 dowel like seals, fitted a new sump, filled it with fluid (It took over 8 litres of LifeGuard 6) and then reset the adaptions.
The car has felt like it’s been driving great but my gearbox lasted 2.5k miles before packing in. When draining it, it was black rather then golden like it went in and it smelt burnt so I’m convinced that resetting my adaptions killed mine despite the new solenoids. I could be wrong though.
If I was in your situation I’d replace the sump and then fill it with fluid so there’s still some old fluid in the box. I’ve bought a 20 litre drum of Smith & Allen LifeGuard 6 so that I can do smaller changes more regularly on the replacement gearbox I’m about to fit to mine.
Post #599902 7th Jul 2021 11:02am
cass
When a man with the knowledge and experience of RRPhil says only use Lifeguard fluid then using anything else to save a few quid sounds a bit risky to me
Post #599934 7th Jul 2021 1:31pm
