Home > Technical (L322) > Rear end knock |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 584 |
There's a recently developed knock coming from the rear right side. It is more of a single "tock", which is barely audible. In its intensity, it resembles the usual noise of the gear selector when brake pedal is pressed while in neutral, or less than that.
28th Jun 2021 5:33pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
Upper or lower hub bushes which are enclosed heim joints are another thing to check, they fail and knock... Pete
28th Jun 2021 7:05pm |
Thanks Pete, noted. That would make sense as any developing play would be longitudinal |
28th Jun 2021 7:21pm |
Buy genuine joints there are some awful cheap ones out there that only last about 6 months... Pete
28th Jun 2021 10:29pm |
You're right. No point replacing them now and having to do them again in six months time!! I used Lemförder, which btw were the priciest, for the front suspension.
29th Jun 2021 5:01am |
When I did the rears on my old fatty had to use an HGV 3/4 drive rattle gun to undo the bolts, it snapped two of them... they are about 15mm so a right PITA...
29th Jun 2021 7:07am |
I know exactly what you mean. Had I known how hard the ball joints and bushes were to remove I would have opted for complete assemblies instead and saved me a day. All this on a practically rust free car! Lesson learned.
29th Jun 2021 7:38am |
